| Hi all,
I want to replace a standard bathroom exhaust fan with a exhaust fan/heater combo. I live in the Chicago suburbs and it can be pretty cold in the bathroom in the morning. My home has the electrical wires running through conduit which I understand is local code. I want to wire the fan/heater in such a way that there is a switch for the fan and one for the heater. During the summer, I'll want to run the fan but not the heater. Can I just run an extra hot and neutral wire through the existing conduit to add another switch? Thanks for your help! |
- Posted by ronnatalie (My Page) on Wed, Jan 5, 11 at 8:15
| Yes you can though sometimes it's a bit rough to pull an additional conductor through a conduit that already has stuff in it. They make double switches that fit where one switch goes. The questions are: 2. Can you shoehorn the unit you want into the space your existing fan is in and get the exhaust duct to line up. |
| You won't need an extra neutral. The fan and heater will share the neutral. You will only need the hot wire to control the heat. |
