Magnets & electricity
Posted by robjr (My Page) on
Sat, Jan 2, 10 at 16:15
My wife just placed about twenty five crystals on our five bulb fixture over the dining table. The crystals are attached to little magnets, about half the size of a dime and about 3/8ths of an inch thick. When she turned on the fixture, three bulbs simultaneously burned out. Coincidence or take the crystals off the fixture?
Rob
RE: Magnets & electricity
They don't call it electro-magnetism for nothing, but in your case it's coincidence.
Changing magnetic fields induce current in conductors, static fields do not.
Unless you have a way to move the magnets and the wire is in their field it is coincidence.
Most likely caused by moving the fixture to attach the crystals.
Probably not entirely a coincidence. The odds are that the lamps may have been in there a while, add in some jostling and shaking of the fixture while the crystals were installed. Lamp filaments are fragile. It doesn't surprise me that a couple lamps burned out actually.
