Thu, Jan 14, 10 at 14:25
| Ok... Boat CFR's and NEC guidelines are not the same as housing.
Installing an older model stove - 3-wire vintage (it was free). Have run 6/3 to a 50A Breaker. 1) Would like the proper way to connect the neutral white wire and ground in the outlet and then in the sub-panel (can neut wht and grnd go together if I keep white and ground together in the breaker box? thanks. |
| 1) Don't. Wire up the outlet for four wires hot,hot,neutral,ground and change the pigtail on the stove to a four prong to match the outlet. As long as you have the correct wiring you might as well do this correctly all the way. |
| I was not sure I could change the stove 3-wire config to a 4-wire. Than makes outlet and breaker box easy, however, I am not sure what to do with the white neutral and ground on the stove. |
| I don't know all the stoves but basically there will be a terminal block for 2 hots and the neutral. There should be a jumper from the chassis to the neutral connection, remove this and fasten the ground to the chassis. |
