| So before I begin I must admit I only recently started to look at generator options since we lost power in my area for 6 days after Sandy hit the NJ area. We managed to survive since my home has primarily natural gas water heater and 2 gas fireplaces. My main concern during the storm was my 2 sumps in my finished basement. I basically had to babysit the pumps to make sure they didn't overflow at any time. I have since then installed a water powered backup pump in my primary pit. I definetely got lucky since the storm brought higher winds then rain in my area. Anyway after researching home standby models and deciding against them due to the huge cost to purchase and install (over $8k for 14-17kw and $10k for 20kw units) Just can't justify the expense for an ocassional power outage. My area has a great history and this was the lognest period of time without power. The main utility lines run underground which obviously helps. |
- Posted by weedmeister (My Page) on Tue, Jan 29, 13 at 16:30
| I hope your dryer is gas. Standing outside in a storm switching over power is not my idea of fun. My friend who has a set up like this has the generator outside connected to an outlet box. This runs to the inside panel. He basically checks the transfer switch on the way out the door, goes out and starts the genny, connects it, comes back inside and hits the switch. He then turns on whatever he needs. He doesn't have to go outside to switch loads when necessary. |
- Posted by studiovette (My Page) on Tue, Jan 29, 13 at 17:17
| Yes gas dryer and stove etc.. Thanks for the feedback. Your point makes sense. Thanks |
