Fri, Jan 15, 10 at 12:08
| I have 200amp service coming in my home that has breakers. I also have a fuse box that supplies electical to part of the house their is a 100amp breaker in the main service box that runs to the fuse box.the main fuses in the fuse box are 100amp fuses thir are two of these.can I change the fuse box with a circuit breaker box If I can do this what size box should I buy 110amp box or 200amp. thanks for any help |
- Posted by ronnatalie (My Page) on Fri, Jan 15, 10 at 16:47
| It doesn't matter. You don't need a breaker in the subpanel (the one replacing the fusebox) at all. Anything 100A or more is legal, but the extra doesn't get you a nything. |
- Posted by spencer_electrician (My Page) on Fri, Jan 15, 10 at 19:05
| If they didn't do it at the upgrade to 200 amps. You will for sure now need to make sure the sub panel is fed with a 4-wire feed (2 hots, neutral, and a ground wire). The neutrals and grounds in the fuse box/ your new sub panel, have to be on separate terminal bars in this case. |
