Defective lamp rewire kit?
Posted by andee (My Page) on
Mon, Jan 30, 12 at 11:02
I'm in the process of rewiring a lamp (which I have done before in the distant past). I'm now ready to attach the cord wire to the socket. It looks like there might be a screw missing? There is nothing else in the packaging. From the instructions, it looks like the brass and silver screws should be opposite. The only non-brass screw is 90 deg. from the brass. The pictures below are three 90 deg. rotations from the position of the brass screw.
I don't want to attach wires to the only two screws there and have the lamp go haywire when I plug it in! Thanks for your help.
Photobucket Photobucket Photobucket Photobucket
RE: Defective lamp rewire kit?
The brass screw should be connected to what feeds the center button in the socket. The silver screw should connect to the exposed metal.
Thanks, I think that is what I observe on the socket. I was confused because the instructions show the screws 180 deg. from each other, and IRL they are 90 deg. And at the 180 deg. position it looks like a little dimple where a screw could possibly be inserted.
I suspect that the "phantom" screw location may be because some or all of the components here are used in the manufacturer of a "3-way" socket.
