| Here's my dilema-
The old sink in my bathroom was a 24 inch sink, on the right side of a 31 inch vanity -- left side was a little counter. The light was located directly above the sink. We're replacing the sink and vanity with a 31 inch model -- and now of course the light won't be centered anymore. So, I need to either move it 3.5 inches to the left. I wouldn't have to cross studs, but the existing box has wires coming in from the top, and both sides, and I don't think I have very much slack. I realize one option would be to use existing box as a junction box, but then I need to keep it accessible == ugly. Another option would be to buy a "3-wide" sconce, and route the wire through one side. However, that limits the available styles (a lot of 3-wide lights still have one 4" attachment in the center). So, I was thinking -- could I make a wooden "bezel" that could cover the existing box? i.e. a 1 foot wide, 4" tall, 1 inch thick board. the light fixture would then get mounted to the wooden board. Wires would go to the backside of the board, which would have a channel routed, such that final connection is within the junction box. Alternatively, I could install a second junction box next to the first, so that all wires are run behind the wall, but the wood board would cover both. Would such a thing be legal? I guess the real question is whether you can use a wooden bezel as a decorative cover to a junction box, or whether it needs to be plastic/metal? Or, if I use the two-box idea, and cover the original box with a metal cover, can I cover this up with a removable piece of wood. |
- Posted by terribletom (My Page) on Sun, Jan 10, 10 at 13:14
| When you used the word "removable", I think you hit the nail on the head. The code requirement, as I see it, is one of accessibility. Unfortunately, that's one of those fuzzy terms that potentially allows for various interpretations by a code inspector. Nevertheless, I'd think that if the cover (whether board or metal) can be easily removed by a couple of screws, you'd be on fairly solid ground. No slam-dunk case, though. |
