Fiberglass or steel door for intense heat exposure?
TimLanai
MODERN HOMESMy Houzz: Modern Exposure and Energy Efficiency in Toronto
A Canadian architect transforms an outdated bungalow into a thoroughly modern family home
Full StoryGREEN BUILDINGInsulation Basics: Heat, R-Value and the Building Envelope
Learn how heat moves through a home and the materials that can stop it, to make sure your insulation is as effective as you think
Full StoryWINDOWSSteel-Framed Windows Leap Forward Into Modern Designs
With a mild-mannered profile but super strength, steel-framed windows are champions of design freedom
Full StoryFLOORSIs Radiant Heating or Cooling Right for You?
Questions to ask before you go for one of these temperature systems in your floors or walls (yes, walls)
Full StoryGREEN BUILDINGHouzz Tour: Passive House in Vermont Slashes Heating Bills
Its ecofriendly, low-maintenance design leaves a family with more time to relax and enjoy the weekend home
Full StoryGARDENING GUIDES10 Drought-Tolerant Shrubs That Thrive in Full Sun and Reflected Heat
Got a hot spot in your garden where plants often die? Try these tough shrubs that add beauty while shrugging off the heat
Full StoryARCHITECTUREArchitectural Sunscreens Take the Heat Off Homes
Sun-blocking screens help you stay cool, play with light and create a stunning modern exterior
Full StoryGREEN BUILDINGEcofriendly Cool: Insulate With Wool, Cork, Old Denim and More
Learn about the pros and cons of healthier alternatives to fiberglass and foam, and when to consider an insulation switch
Full StoryFRONT DOOR COLORSFront and Center Color: When to Paint Your Door Bright Red
Welcoming and intense, a red front door kicks up a home's entryway and is impossible to miss
Full StoryMATERIALSCor-Ten Steel Brings Enduring Texture to Landscapes
With its rich color and rusty patina, this material makes for an arresting and long-lasting choice for garden walls and more
Full StoryMore Discussions
Windows on Washington Ltd
mmarse1
Clark Window Contractors · Goulds Window Contractors · Hammond Window Contractors · Huntley Window Contractors · Kearns Window Contractors · Ruskin Window Contractors · Wilmington Window Contractors · Sacramento Window Contractors · Markham General Contractors · Montclair General Contractors · Poquoson General Contractors · Summit General Contractors · Tuckahoe General Contractors · Williston General Contractors · Avocado Heights General ContractorsHomeSealed
