Windows Frosting up Question
Posted by andrelaplume2 (My Page) on
Wed, Dec 6, 06 at 15:01
We just moved into a 20 year old home. The prior owner was maticulous in documentaing and maintaing everything. He appears to have had built a very good quality Colonial. I even have the specification for the home. It came standard with CrestLine double hung tilt-in windows. We notice the windows do not tilt in but are double hung. A neighbor theorized that the original owner upgraded to Anderson Windows when the home was built and that the Anderson's, while they did not tilt in were a superior quality over the Crestlines. Who knows! Anyway, so far they do not appear drafty and go up and down quite easily. I just raised all the screens and lowered the storm windows. I notice on some mornings some windows have a layer of frost. What causes this? Is there anything I can do about it? Is this how things were back then? Do I need to replace these windows. Thanks!
re: i should mention too...
that the frost is on the storm windows...not the interior double hung window...so far anyway.
RE: Windows Frosting up Question
If these are Andersen's you will know it because they will have a logo, or "bug" (in window tech-speak) in a lower corner of the units.
If it doesn't say Andersen on the glass, then they are someone elses windows.
And to the point, you have frost on the storms because the temperature of the glass in the storms is below freezing. Of course to have frost you must first have moisture - and that moisture is coming thru your windows, along with warm air, and there is enough moisture in there to allow condensation to form within the space between the double hungs and the storms.
When it is cold enough outside to cause the storms to have frost, it doesn't take very much moisture to have condensation. The best way to stop moisture (and heat) from leaving your home is to ensure that the current windows are weather tight. Ensure that weatherstripping is intact and that the windows are locked when closed.
I am adding a rather long post that I wrote a couple of years ago that (I hope) helps explain condensation on windows. I post it several times around this time of year because window condensation is not uncommon given the right set of circumstances.
The reason why there is condensation or frost or ice on the interior of your interior window or storm window has a rather simple explanation the surface temperature of the window is below the dew point temperature of the air in your homethats ita very simple explanation.
Unfortunately, the explanation as to why the window surface temperature of your windows is below the dew point temperature of your home is potentially a bit more complex but I am going to offer a few thoughts and even throw in a few numbers that I hope might help your situation.
In the summer, when you pull something cold and refreshing out of the refrigerator, and the air is warm and humid, that cold and refreshing beverage container suddenly and quite magically becomes instantly wet just as soon as it is exposed to the air. What has happened is that the temperature of the container fresh from the refrigerator is below the dew point temperature of the air which has caused condensation on the outside of that container.
What happens to your windows in the fall and winter is that the surface of the glass is below the dew point temperature of the air in your home which is causing condensation on the surface of that glass.
Dew point is defined as saturation vapor density...or put in simpler terms, when the air reaches 100% relative humidity and can hold no more moisture.
Relative humidity is, well, relative.
Relative humidity is a comparison of the actual vapor density versus the saturation vapor density at a particular temperature. Put a bit more simply, dew point is 100% relative humidity or the point where the air - at that temperature - is no longer able to hold any more moisture. If the air has reached vapor saturation (100% relative humidity), then the air will release moisture...be it on the outside of that cold beverage container in the summer time, or be it on the interior glass surface of your windows in the winter time, it makes no difference. If the surface temperature happens to be below freezing, then that moisture becomes frost or even ice.
In order to stop condensation from forming on the surface of a window, you either have to lower the dew point temperature of the air in your home to a level below the dew point temperature of the window surface, or you have to warm up the window surface to a temperature above the dew point temperature of your home, or a combination of both.
Lowering the relative humidity of the air in your home MAY have absolutely no effect on controlling window condensationand I bet that that statement is a bit of a surprise to some folksit is true however because there are two ways to lower relative humidity increase air temperature or decrease moisture content. If you increase the air temperature you will lower the relative humidity but you will not change the dew point - which is based on the amount of water vapor in the air and is not based on the temperature of the air.
The amount of moisture in the air is measured in grams per cubic meter, which is kind of nice for our metric folks but not so nice for our non-metric folks; but the metric version is much easier on the calculator than the English version. However, in the interest of making this stuff easier to understand for all of us non-metric types, I am going to use Fahrenheit rather than Celsius temperatures in the calculations.
Okay consider your home at 65 degrees F and with a relative humidity reading of 40%. There are 6.25 grams of water in a cubic meter of air in your home in that particular scenario - which then equates to a dew point temperature of 38 degrees F. So at 38 degrees the air will be at 100% relative humidity or at saturation vapor density.
Now, if your neighbor keeps her house at 75 degrees, but she also has 6.25 grams of water per cubic meter in her air, then the relative humidity in her home is 29% - versus your 40%. But, and heres the kicker, the dew point temperature in her home is still 38 degrees.
While the relative humidity in her home is much lower than is the relative humidity in yours; if the surface temperature of the windows in her home is 35 degrees she will have condensation on those windowsyet if the surface temperature of your windows is 40 degrees only five degrees warmer you will not have condensation on your windows.
So, while her handy humidity gauge reads (correctly) only 29% RH she has a condensation problem.
While your handy humidity gauge reads (correctly) 40% RH you dont have a condensation problemSWEETwell, for you anyway, not her.
If your home hygrometer measures the relative humidity in your home at 60% while the temperature of your home is 70 degrees, you will have a dew point temperature of about 51 degrees meaning that if the temperature of the window surface is below 51 degrees then you will have condensation - so now we talk a little more specifically about windows.
The interior surface temperature of a single lite of glass, when the temperature outside is 0 degrees F and the inside air temperature is 70 degrees, will be about 16 degrees.
Add a storm window on the outside and the surface temperature of the inside lite jumps up to about 43 degrees a huge improvement.
But these are center-of-glass readings and not the temperature readings at the edge of the window where condensation usually forms. A typical clear glass dual pane window is going to have center-of-glass temperature reading pretty much the same as a single pane with a storm something that is often claimed (correctly) by folks who advocate refurbishing windows rather than replacing (something that I am not going into here I am NOT advocating either replacement or restoration in this post. It is long enough and detailed enough already without opening that particular can-of-worms!)
However, if that dual pane has a LowE coating and an argon gas infill then the center-of-glass temperature will be about 57 degrees a 14 degree improvement over a clear glass dual pane or a single pane with storm window but again, and more importantly, there will be a comparable edge of glass improvement as well, particularly if the IGU (Insulating Glass Unit) was manufactured using a warm edge spacer system. Also, the dual pane is going to have desiccant between the glass layers. Desiccant absorbs moisture keeping the inside of the dual pane system very dry.
The advantage? If it gets cold enough outside, the temperature in the airspace between the lites can get very low. By keeping that space dry, it helps to keep the dew point temperature very low as well; something not always possible when using a single pane and storm window.
Although a single pane with a good and tight storm window can help the interior lite to avoid condensation (when compared with a single lite and no storm), the storm window itself will frost up when the temperature is low enough at a temperature usually well above the temperature that will cause the dual pane to ice up. It is unavoidable given the right circumstances
So what does a window temperature of 57 degrees mean? Well, as I mentioned earlier a home kept at 70 degrees with a 60% relative humidity has a dew point temperature of 51 degrees so it is unlikely that there will be condensation problem on those particular windows despite the relatively high relative humidity in the home.
But what happens to the dew point if you keep your home at 70 degrees and you have a 65% relative humidity? Well, for one thing the dew point has jumped up to 57 degrees which we have already noted is the same as the window temperature. For another thing, anyone with 65% relative humidity in a home at 70 degrees has way too much moisture in their air and they are in serious need of some sort of ventilation system or at least several good exhaust fans!
Somewhere back in this post I mentioned that lowering the relative humidity in your home may not help control condensationthat is still trueIF the relative humidity is lowered because of an increase in temperature. But, lowering the relative humidity by removing water is a different story because in that case you will also be lowering the dew point as you lower the relative humidity and that WILL help to control condensation on your windows.
thanks..a lot to absorb but I will read thru it!
