| I have a 20 yr old acrylic double dome skylight which lets a lot of air in and the frame sweats inside. Decided to replace it with a Velux 2246 0075 (fixed curb mount). Thought it would be a simple change.
On removing the old skylight found two problems. 1. The drywall extends about 5/8" above the curb due to an offset in the old frame. 2. Some of the flashing is folded over the top of the curb (not every piece). Obviously the Velux would not fit and seal. The drywall can be trimmed. What is best way to trim flush with top of curb? Saw or score and break off? Concerned about appearance. It looks like a sloppy job by the roofer on original roof to leave some flashing folded over the top of the curb.
The Velux does look like a much better skylight. What would be a fair labor cost to trim the drywall and flashing and install the skylight? The roof is steep but easily reached from the driveway with a long ladder. Thanks, |
| I am having a tough time understanding from your post. Please post some pictures if you can as they may help explain it. As far as cutting flashing on your new unit if that's what you mean, IN NO WAY CUT THE FLASHING. |
Return to the Windows Forum
