Fri, Nov 11, 11 at 23:03
| Recently I had the pride of owning a old home from sixties. The sunroom has some anderson awning window but they do not have model number written anywhere. Atleast two windows has the mounting shoes worn out and I am desperately in need of the right part. Please see the worn out parts below. If you can, please give me a pointer as to where should I look for the parts. |
| It may not have any part number since it was not considered a replaceable/sparable item. |
- Posted by millworkman (millwork4u@gmail.com) on Mon, Nov 14, 11 at 11:12
| They would be called Flex Vent or Rotolock Shoes and are handed so a window would have a Right and a Left shoe. Check with an Andersen distributor locally they would be able to order based on the description if they are available individually. Due to the age of the units you may need to purchase the entire operator mechanism to get these parts as they may no longer be available by themselves. |
| They would not be very hard to make from scratch using just hand tools. |
Return to the Windows Forum
