| I had a contractor replace some windows while his crew was residing one of my exterior walls. The finished look leaves a bit to be desired, which I kinda anticipated. I previously had a very shallow aluminum window with dry wall return and another set of vinyl windows that were just a bit deeper than the fiberglass windows I replaced all three with. The new windows are new construction style and were installed from the outside. I’m trying to figure out how to get a finished look with my new windows.
Here’s the first window:
Here’s the second window:
Third Window is similar to the second, but not as bad. I’m trying to figure out what to do. I could probably case out the first window, but I have 6 windows that are like the second one pictured, where casing isn’t an option, so I’m probably not going to do that. The other option would be to have the dry wall returns redone. I’d have to hire that out. The other option would be to add some sort of screen moulding or other type of trim to “case” out the window. I’d probably go with PVC trim. I read about a similar approach in a thread a while aback and it seemed that the consensus was that that it was tacky. So, if you were in my shoes, what would you do? |
- Posted by windowsonwashington (info@windowsonwashington.net) on Wed, Nov 9, 11 at 7:47
| Most installers would mitre cut a piece of 1/4 round to cover that rough edge and but it up right to that wall to window connection. |
Return to the Windows Forum
