Eagle Windows -- Defective Design
Posted by catalyst-cpr (My Page) on
Sat, Nov 15, 08 at 16:22
I am a construction consultant and have been working for several years now dealing with problems with Eagle Windows and believe that there is an inherent design flaw in how they construct their windows. The problem manifests itself particularly with their "Auxiliary Units", that is, their fixed pane windows.
The problem is that they are designed with the presumption that none of the sealants, joints or other mechanical connections in the frame or interfaces between the glass, wood and metal will ever fail. But if they do fail, problems of moisture intrusion into the structures behind the windows and the wood members of the windows themselves can deteriorate for a long time, undetected. Once this intrusion is finally detected though drywall damage, mold, or other problems, usually significant internal deterioration has already taken place.
Most windows I've encountered over the 40+ years in the construction field are designed to have secondary or tertiary mechanisms to allow any water that gets past the first line of defense to escape. Channels and weep holes are typical of these devices. Many windows are stopped in from the outside and have a vertical barrier to wind driven moisture at the interior side of the glass in addition to the interior sealant.
Eagle Windows are designed in such a way that the permanent stop that the glass is sealed to is located outside the glass, i.e. the glass is set from the inside. The glass is set in a glazing bed about 1/32" thick and about 1/4" wide. The corners of the metal frame are simply mitered and screwed together. There is a tiny bead of sealant at these joints. An optional "sill nose brickmold" snaps up into the bottom of the frame with a small ~3/32" fin and into a field applied sealant. Brickmolds are not integral with the main frame. The glass is stopped in on the inside with a small wooden moulding. This moulding has a thin foam weather stripping between it and the glass.
The ultimate result of this design is that waterproofing of Eagle Windows is SOLELY reliant on sealants/caulking. As wind and temperature changes move or expand and contract the multiple different components of the windows, the sealants slowly or rapidly deteriorate and moisture penetrates. When the glazing setting bed of sealant fails, water migrates directly to the wood frame of the window. I've seen thousands of dollars of damage to high end millwork, hardwood floors and carpet as a result.
There is no good repair to this condition other that perhaps removing the glazing from the window frames and installing some type of weep system. We are currently exploring this option.
Which brings me to my last point. If you explore the history of Eagle Windows, they have recently changed hands/ownership every few years. A client won a $146,000 judgment against them only to find out that shortly before the judgment was rendered, Eagle was purchased by its creditors, and in doing so the purchaser wrote into their documents that they assumed none of the liabilities of the former company. Same name, same president, same address, just a different company. When we tried to execute on the judgment, their attorney threatened to sue using their liability waiver and the claim that they were no longer the same company as the basis of the threat.
They were then purchased a year or two later by Anderson Windows, but continue to operate under the same name, in the same location and continue to use the same defective designs.
If you are considering using Eagle Windows (or any other windows for that matter), carefully analyze the window's design details in light of my comments. I hope this will help at least one person from making the mistakes several others are dealing with.
RE: Eagle Windows -- Defective Design
It sounds like you have a grudge against a particular window company. The bulk of your description of the window detailing describes a common design used by the majority of clad-wood window manufacturers today. They all rely too heavily on a waterproof membrane to eliminate water infiltration at the point where the cladding meets the glass. Unless one builds a window utilizing glass as the cladding substrate, the glazing leg will always have a different expansion coefficient than the glass. Thus, an expandable glazing compound must be utilized to eliminate separation between the glass and cladding. Some use butyl, others use foam tape with silicone, while others even still use plastic "boots".
Similar to traditional all-wood windows, a user must maintain the exterior glazing leg in order to eliminate wood rot or water intrusion. Old glazing compound required removal and re-glazing periodically, in order to protect the older windows. This is no different than modern clad-wood windows, except that the exterior glazing leg does not show obvious signs of needing repair. If a user elects to maintain a wood window, regardless of it being a 100 years old window or a 10 years old one, they will either reglaze the glazing leg of an all-wood window or place a bead of silicone on the exterior metal glazing leg where the glass meets the metal. It is only common sense that these waterproof compounds used in window construction have limited lifespans and will require upkeep.
We're curious about your reference to a weep system. Are you intending to presume that there are companies that allow water to run behind the cladding, into the wood, and then "breathe" back out from behind the cladding? We've observed one such manufacturer that designed a fixed clad-wood window that had "slits" cut into the metal and across the face of the vertical frame leg. Outside of this odd concept of allowing moisture to penetrate beind the cladding, the aesthetic value of these "slits" was very unsightly.
We've used Eagle products for the past 25 years and have never had a concern for their methods of construction, and we feel that their engineering design is top-notch. However, we are fully aware of the potential for water infiltration at the glazing leg area in all clad wood windows, regardless of the brand being Eagle, Kolbe or Marvin. We mention these three companies, as these manufacturers have been approved for our custom building requirements based on their ability to provide highly durable construction methods within their designs. Since you've had a problem with one of them, we'd like to know which manufacturer you would suggest has a better design and we'll take a look at them?
We also found your comments interesting regarding the change in ownership of a large manufacturer. Your comment insinuates that a multi-million dollar a year organization would change ownership based on a $100K lawsuit. I believe that you sir have a hidden adjenda to discredit a reputable manufacture on this board.
You "Sir" need to read this following excerpt from a letter my client received from Douglas M. Henry, of Fuerste, Carew, Coyle, Juergens and Sudmeier, PC, attorneys for Eagle Window and Door, Inc. in 2004 and before being acquired by Anderson Windows, before accusing me of having a hidden agenda:
"The windows in this case were manufactured in the second quarter of 2000 by a company called Eagle & Taylor Company, d/b/a Eagle Window & Door, Inc. That is the company that sold the windows and gave the warranty upon which your client relies. In December, 2000, that company became a debtor in United States Bankruptcy Court for the Northern District of Ohio, Eastern Division as a subsidiary of American Architectural Products Corporation, jointly administered Case No. 00-43726. On April 19, 2002 an Order was entered approving sale of the assets of that company to my client. I enclose a copy of this Order. My client was originally incorporated as EWD Acquisition Company in April, 2002. I enclose a copy of the application for certificate of authority filed with the Iowa Secretary of State on April 30, 2002. Initially, EWD Acquisition Company adopted the fictitious name Eagle Window & Door, Inc. I enclose a copy of the fictitious name resolution filed with the our Secretary of State (extra word was added by their attorney), also on April 30, 2002. Subsequently, EWD Acquisition Company changed its corporate name to Eagle Window & Door, Inc. I enclose a copy of the application for amended certificate of authority filed with the our Secretary of State on June 18, 2002.
"The Order specifically provided that under no circumstances was EWD Acquisition to be deemed a successor of the Debtor/Seller. The warranty obligation to your clients was not assumed by my client as Buyer and the Order enjoins your client from pursuing this claim against my client."
The letter goes on to threaten "Having given you this notification of the terms of the Bankruptcy Court Order, we may choose to seek an order to show cause why your client should not be held in contempt for filing such a suit in defiance of the Bankruptcy Court."
If you would like a copy of the enclosures, I'd be happy to e-mail them to you.
As you can see, this company has been playing shell games with its identity and responsibility to its customers for at least 9 years. They used to have a long history description on their website describing how they have changed hands many times trying to tell a story of going back a hundred years, somehow indicating old world ethics and craftsmanship.
I stand by my assertion that the design of these windows is seriously defective. I would be happy to demonstrate quality design of windows that don't leak or cause unseen internal deterioration from the hand built wood windows my dad built to the cheapest aluminum and vinyl windows to high quality windows. Good building exterior cladding design requires a minimum of two level of defense from the elements. Eagle's provides only one flawed method -- a poorly developed and designed sealant bead.
As a reputable "multimillion dollar manufacturer", the fact that they refused to stand up for their product rather than hide behind Bankruptcy, conniving, and attorney's apron strings and then threaten their customers with contempt of court shows they are less than reputable.
If I have a grudge, it's a result of this repeated deceit and immoral business practice that cost my clients thousands of dollars that I base my assertion.
Other window designs may be similar, but I'd advise anyone considering buying them to look seriously at this fatal flaw and buy wisely.
I Agree with catalyst-cpr. I've owned Eagle windows for the past 3 yrs and have had numerous problems. The worst has been water penetration. Please tell me what specific problems for which I should look in the future or should I just get rid of them ASAP?
How have they responded to your warranty requests? Were they owned by Anderson when you bought them?
What model Eagle windows are you talking about?
I believe it was call their wood clad window. It has an aluminum extruded exterior attached to a wood interior to which the liners and sills are attached.
This is to mcsbldr. I am curious. It sounds like you have some stock in Eagle windows.
To Catalyst
We have also had horrible problems with Eagle Windows. We had an addition put on our house four years ago and we chose Eagle Windows to put placed in the new addition. Part of the new addition faces out towards the lake that we over look and so occasionally due to our location we can get some really wind driven rain. Not long after they were installed we started to notice wet carpets beneath two of the windows. Our contractor who has been wonderful came back to see what the issue was. We even had Eagle Window out and they said it had to be a installation issue. Needless to say after repeated attempts to fix the issue we still had these leaks appearing every once in a while. Just recently we had another rain driven storm and this time my contractor opened the wall (for a second time) while it was raining heavily. The leak was coming from underneath the window. After much investigating we have found that the rain is being driven in at the side of the windows, getting trapped behind the jamb liner and penetrating into the wooden frame of the window and then working its way under the window. I was extremely upset and when I repeated the experiment on other windows they all failed the test. Eagle tells me that all they need to do is replace the caulking where needed, replace the pads for the jambs and add weather stripping to the bottom of the sill. I would understand it if it was just one window, but it is every single window. I believe that it is more a design defect than a caulking fix! These are the double hung windows and are simple not designed to handle wind driven rain. Do you have any thoughts on this and have you seen this problem with Eagle windows? Your opinions would be much appreciated. I would be more than happy to inform anybody of how to test these windows just as we have. Interestingly, I did find another posting by somebody called JackJack in 2006 who had his Eagle Windows installed in 1995 and all his wood frame is rotting out at the corner of his windows. His discription of the problem that he has discovered sounds exactly what is happening to our windows!
"the rain is being driven in at the side of the windows"
Could you be more specific about how the water gets in? Is it a frame defect, a nailing fin defect, or a sash to frame defect?
I believe it is a sash to frame defect. You have to understand this leak only becomes very obvious when the wind is driving the rain into the windows. There are no signs of leaking unless you have the driving winds. The water builds up and does not run off quick enough with the screens in place. It becomes trapped behind the jamb liner and then gets through the caulking and into the interior wooded structure of the window. We took a video of how this exactly happens and when Eagle came the last time they took the frame out of the window and you could see water damage on the interior wooden frame about 6 to 8 inches from the bottom of the window. Even on one of my windows that hasn't leaked to my knowledge, I could still see water entering the wood frame by the water experiment we performed. Definitely some design fault! Do you have Eagle windows? If so, have you had some leaking issues?
Window frames shouldn't leak... but sometimes they do. That is why every contractor should use some sort of a sill pan or water management system. If water is getting into the walls and affecting the flooring you chose the wrong installer.
Just installed 18 eagle axioms aluminum casements windows in July 2008
. during the summer they did a excellent job, but winter came and now I have the biggest problem, every single eagle window leaks air when the temperature gets at 15 degrees or below,frost forms between the sash and the frame in every corner of the window and progresses all the way to the side of the sash. Contacted the company that installed them which is an eagle dealer, they took humidity readings that were right at 28% at a temperature of 70 degrees, they say no humidity issues there but never gave an explanation why the windows are doing that.To me it seems that the weatherstripping gets so cold that it shrinks and causes the leak. 4 weeks have gone by and never heard from them or Eagle company which they were notified also. Extremely Dissappointed with there product and there customer service, at this time I could NOT RECOMMEND EAGLE WINDOWS TO ANYONE. Just wondering if anyone else have the same or similar problems with eagle axiom casement aluminum cladding.
Carpy.... Wow at those temps and humidity levels you must have an open hole to the exterior in order to form frost.
One test you might want to try on the weather seals is putting a piece of paper between them when the window is closed and locked. If it freely moves you have no seal.
Ibwindows yes I did that test and you are right on. The windows is loosing its seal. I just found out that the bulb seal eagle uses is hollow, so is prone to shrinkage. i am still trying to get them to come and change the bulb seals in all the windows with a solid core ones. To bad that this company has sooooo poor customer service.
Actually a bulb seal, because it can be compressed more then a solid should be giving you a better seal. If the bulb is shrinking due to temp, your problem is.... it is barely touching at higher temps. You want that bulb to be smashed flat when the window is closed and locked. Solid core isn't the solution IMHO.
then what solution I should be having to correct the problem?
the seal is pancake flat. if the seal have an inner core then there is constant pressure which in turn would keep its original state, no where to get flatten.
Without actually seeing it my first fix would be a slightly larger bulb that remains flexible in cold weather.
With solid it's gonna bottom out where ever it first touches
To asfraser
Sounds like you and I have had similar problems with water penetration around and underneath the Eagle windows. Water penetrated usually under the half circle and radius windows either with or without the mullion joint. I'd like to know how you performed your water test and if you noticed water behind the miter joints of the aluminum cladding or rotting the OSB beneath the windows.Have you also had water entering the interior going around the window pane unto the inside sill and unto the floor.
Have the same or a similar problem with Eagle windows and doors. would be interested in knowing more about the law suit and any other information you might have as Eagle is not living up to their warranty. can you provide more details. Thanks. Greatly appreciated.
We have had Eagle windows for 20 years and have had nothing but problems. After years of caulking and tearing all the siding off to re-do we have finally come to the conclusion that the window seals leak in heavy wind/rain storms. We are replacing all with Anderson.
To verify, 14sley, Bigman
I am not surprised to hear that you have similar problems. We have currently got a warranty claim with Eagle who are sending out another tech to inspect the windows this week. Their distributor had offered to try and caulk the leak, but we feel this is just simply a bandaid to the problem because caulking is not warranted for 20 years and all the windows leak which indicates not just poor workmanship on one particular window but a fundamental design fault for fairly heavy wind and rain issues. As to the note posted by VERIFY sorry I haven't checked this web page for quite some time. The water did get into the interior with wet carpeting and this is how we realised there was some problem. You need to pour water onto the side of the windows above the side jambs (keep your screens in). The volume of water will build up that you will notice water coming up in the joint where the window sits. Sorry I am not familiar with technical jargon but am happy to provide anymore information that I can. I will check this website much more frequently now that more people are coming forth. I will let you know how the warranty claim is going!!!!!
Not sure what made me to decide to look at this site today, but I am sure glad I did. My only post was back in 2006 when I was desperately seeking information about my leaking Eagle Windows and the damage that was caused. It appears there are more homeowners with the same exact problems that I have experienced. Back in 2006 according to Mike35 where he states "your problem goes way beyond windows". My question to Mike35......Is it just a coincidence that the damage to the windows, framing, sheeting and siding just happened to be located at the bottom corner of each first floor window (second floor windows protected via eaves). Lets assume the windows were installed according to the Eagle installation instructions provide at that time, which they were - I installed them and my Eagle rep was at the jobsite from time to time checking up on progress. Why did the "Sub Sill" come into existence, It was not mentioned in 1995? Did asfraser have the same installer? Don’t think so. It is obvious to me, and apparently to others, the windows to not drain away water properly, therefor water soaks up into the foam behind the vinyl side jamb inserts, then over time seeps between the sill and wood side jambs into the framing and beyond. I feel fortunate I had wood siding, If it were vinyl or brick you would never see the problem. I feel sorry for those homeowners!
I recently had an independent lab(TLS Laboratories) out of California test a small number of my windows and doors and found a > than 50% failure rate of preventing water penetration and 75% failure of the installation procedures. So you can see I've had the perfect storm occur and consequently I will need a major renovation. If you live on the coastline of a large body of water Eagle windows do not perform.
Follow up on previous Eagle windows
I forgot to ask asfraser how is the warranty claim going? I ALSO AGREE with jackjack that if I did not have wood siding I also would not have noticed the window problems and the installation deficiencies!
I have same condition as asfraser. I do not have screens installed and it still gets rain water blown under the side jam extrusion where it meets the sill. Behind this extrusion is just some thin foam and bare wood that is wet for @6" up and water weeps down. I had my contractor here yesterday doing water testing and the water is going out over my house sheeting and down to my foundation sill and then coming back into the house into the basement. Unfortunately we only figured out it is this window design issue after replacing damaged wood rot of window trim and house sheething and pulling the siding and replacing the house wrap. I now know my house is tight behind my siding but the windows leak. I view the design fault is that the side frame behind the extrusion is bare wood and the 90 deg joint of sill to side frame is not waterproofed or sealed. My plan is to pop out the jam extrusion and polyurethane the wood to waterproof it (but allow it to stay clear to inspect for future water leak) and silicone caulk at the 90 deg joint. I will then snap the extrusion back in. I do not plan to seal the extrusion at the bottom so if water does get in this cavity it can drain out the bottom and onto the sill and out the front as it should. I will probably seal the front seam of the extrusion running up the jam as this is just a snap fit joint. Does anyone have experience of repairing these windows or comments on my plan? Thanks!
I actually put my screens back in hoping that wind driven rain will get slowed down, is this a bad idea that will cause a pool? My additional plan is to convert the exterior window screens into storm windows by attaching plexiglass or thin sheet glass to the screen frame. Thoughts? Thanks!
Finished the urethane base covered by silicone caulk. Ended up able to smear the silicone up the wood jam 2-3 inches. Decided to remove screens per comments here about pooling. I could clearly see how with the screens in the window that the sill will not drain easily and the top of the screen frame is as high as the bottome of the window. Also since my leaks have happened without screens installed I wanted to keep the conditions the same thru the next wind driven rain event to test the fix "apples to apples". Will post when I find out if it worked but honestly do not see how it couldn't but water is a tough battle....
I believe I just found the problem of the leaking Eagle window. When the rubber weather strip on the top of the bottom of the window deteriorates the seem under it is not sealed. With screens the driving rain is diverted. Without the screen the rain is pushed under the window and down usually starting at the corners. I placed saran wrap under the window today while it is raining and leaking and it stopped the leak!. I also removed sheetrock from under the corner and poured water on the seam. I was able to see the water dripping down. I will remove the old weatherstrip, silicone the seam and replace with a new weather strip.
Have now had wind driven rains with no leaks! Have opened window jam track to verify caulk is holding and working! FYI: Corner leak was also happening on Simonton Quantum II vinyl replacement windows leading me to believe that many manufacturers do not seal the corner of the sill to jam very well.... A tube of silicone goes a long way to stop this from already installed windows and/or if new install then install sill drip pans in the wall opening prior to installing the windows. Please note the leaks were not obvious, I pulled the insulation out of the joist headers in my basement below the windows to discover water leak evidence and track back up. I suggest homeowners look behind the joist header insulation in their basements under windows for this sleeper problem. No leak and the insulation was pink and wood looks new, leak and insulation was blackened and the wood showed signs of water staining or actually wet in heavy rains. Hope this helps others with these sleeper water problems that will rot wood over time!
Simonton doesn't make the Quantum II window. It used to be made by Kensington Windows until they were purchased by Serious Windows.
Thanks for the correction. They are Kensington. I assume they would not be covered by any warranty after banckruptcy and new ownership.... The installer is also out of business so that "lifetime transferrable warranty" is useless. Caulking the seam from sill to jam has stopped the corners from leaking in wind driven rain. Basic point is that many window brands seem susceptable to this corner leak in wind driven rain issue and having a secondary water management like a sill pan in the rough opening is a good idea to keep water on the exterior house envelope. Also found an interesting tutorial for additional suspender & belt water management with flashing at albertsroofing.com.
To asfraser
Sorry I haven't checked this site for a long time since we were busy with remediation starting last Aug 2009 and finishing in Feb. Since mediation was fruitless we had to start a lawsuit against Eagle and our first builder. How is your warranty by Eagle proceeding?
To lake-effect
I think a construction consultant like catalyst has had experience fixing the Eagle window defects.
I have replaced almost all of my eagle windows with Andersen's and we will know soon enough if they work better than Eagle's.
verify, that's interesting. Is Anderson doing anything price wise to help you out as they are now the proud owners of Eagle Windows.
In 2008 after a period of heavy rains, my husband and I began smelling an increasingly bad smell toward the west end of our fully bricked home. Upon opening the wall, we found moisture within the wall of our home, concentrated in the area of our Eagle windows. There was moisture and mold on the exterior side of our polyurethane vapor barrier and the fiberglass insulation was quite wet. While there was no obvious water staining, there was some mold on the OSB sheathing most concentrated in the area below the windows and adjacent to the heads.
Over 20K was spent to determine the source of the problem and correct it, including mold testing & remediation and hiring consultation from an engineering firm that told us the problem was due to improper installation of the windows throughout our home.
Per the engineer's recommendations and with his oversight, the limestone sills were removed and flexible through-wall flashing with end dams tied into the bottom of the nailing fins were added. The sills were reset at an angle to increase water run-off, and the sills were set lower allowing for a more adequate 1/4" sealing space. The sill head joints were also raked back allowing for improved sealant space. The existing sealant was removed and commercial grade sealant was professionally installed around the perimeter and sill head joints. In addition, the fiberglass insulation in the shim spaces was removed and minimally expanding closed cell urethane foam insulation was installed in the shim spaces to decrease air flow. Spray foam insulation was put in the walls and new drywall was put up and painted. We thought the problem was finally behind us. This summer we purchased another home to live closer to family and put ours on the market.
Now, here we go AGAIN! The home inspector for potential buyers used a moisture detector and found moisture at the bottom corners of two window sills, same west wall. After heavy rains, we're once again having a noxious smell in our home. Initially we thought it was just off-gassing from the new products in our wall, and upon having the engineer return to our home we were reassured that's all it was. Yet over this past week, the smell has become worse. Obviously we can't sell our home with this problem (and we wouldn't attempt to). This whole situation has become a financial nightmare.
Is there anyone out there who knows of a good construction consultant in our area having experience with this? (Eastern IA near NW Illinois and SW Wisconsin) We're becoming desperate to figure out how to fix this problem and don't know what to do! We're not positive it's the Eagle windows but we're wondering. Catalyst, where are you???
Forgot to mention, our home is only 8 years old. Unfortunately, though, it appears there may not be much recourse there since apparently the previous owner served as the general contractor, and he was unlicensed. We'll never make THAT mistake again!
We have just discovered thousands of dollars in damage to my parents lake house due to Eagle Windows. Water has been leaking for years and has rotted out everything behind the walls and below the windows. We had no idea until we went to replace a window sill and discovered the mess. Has anyone had any luck pursuing legal action against this company?
This thread is upsetting. I just looked at Eagle casements and DH's and found them to be quite nicely constructed. No, I didn't test them for water penetration, but they do make a good looking window.
Has there been changes made recently that have corrected the previous issues?
I used Eagle aluminum clad double-hungs on a house on the ocean on Cape Cod. Almost immediately they leaked from wind driven rain and the rep had to make repeated visits to fix them. I believe the problem was the glazing seal to the sash.
Anderson is a window company but it was Andersen that bought Eagle.
MACV, re water intrusion issues, on another post you mentioned "Both the Integrity DH and the Ultimate DH windows need a projecting sub-sill added to avoid water intrusion problems since neither has a proper drip at the nose of the sill". Could that have been the same issue with the Eagles? I'm curious if was the clad seal, sash seal, etc. Could you find out, please?
I think there is so much written here with window problems here that a causual reader would be totally confused. All windows have some issues, and couple that with installation issues, then you have a perfect storm.
Beginning to look like someone with Legal Knowledge ought to get a class suite going against Eagle/Anderson.
Interesting thread. So the original Eagle went belly up and left its customers holding the bag. But how have the insurers managed to get off scott free? I'm not a lawyer, but I've been involved in several situations where the bankruptcy court having jurisdiction allowed litigation to proceed to the extent insurance coverage is available. The policy of insurance would have to be examined by a skilled eye to determine if there is anything there to pursue and, if so, whether the inevitable exclusions can be finessed. I also wonder if some recourse might not be available against the insurers of some of these rogue contractors.
"Beginning to look like someone with Legal Knowledge ought to get a class suite going against Eagle/Anderson."
Pella is presently defending itself in a class action suite over similar problems (part of it made it to the Supreme Court)..
The whole idea of cladding wood to 'protect it' has never worked for very long for anyone.
Moisture eventually gets through, and then hidden rot starts.
brickeyee, I have seen you state the same thing many times over and am curious as to your definition of very long in this statement?
"The whole idea of cladding wood to 'protect it' has never worked for very long"
I am an employee of Eagle Windows in Dubuque. Since everyone here has been having problems, does anyone have a possible solution. It seems to me that everyone now-adays wants to sue someone else. I know for a fact that our customer service reps bust their humps to fix problems. If you find a perfect design that will never fail then you should sell it to us, then maybe we can make 100% of people happy 100% of the time. I do believe that is why there are different company's out there selling the same product.
chade.....you make the windows.....you take our money.....you find a better way.....i'll buy a different window for now!!!!!!
Well my neighbor has the same issue, same windows...Eagle is consistent... Chade, a possible solution - design to manage secondary water leaks like wind driven rain going thru seams (unsealed in this case...stupid...). An integrated drip cap, flashing and sill pan to drian out over the next course of siding below like the albertsroofing.com solution.... Basically design for belt and suspenders with primary and secondary water management and design to make "contractor" proof for installation mistakes. Want a great solution, come to my neighborhood to learn and see the issue first hand and fix our windows for free....
Here is a link that might be useful: albertsroofing.com window flashing
All of this bankruptcy talk is incorrect. Eagle's parent company at the time was AAPC (American architectural products). They went bankrupt and as a result were forced to sell eagle since it was their only profitable company it owned. I have been an Eagle dealer for over 15,years. Has there been problems? Sure. All companies have and deal with them. There are no design flaws as stated earlier. Numerous factors go into water leaks. Sometines window issues sometimes install sometimes surrounding areas. I have been very satisfied with Eagle's service not only to me but,my customers as well. They do take care of problems that are theirs. Some people have hidden agendas here.
Just wanted to give an update on the outcome of our home situation. After hiring a very knowledgeable moisture intrusion expert from Des Moines, we learned that there were areas of defective mortar in our fully bricked home. Since there were no weep holes or flashing in the brick walls, and since there was moisture trapped behind our walls after very heavy wind-driven rain, on really hot summer days a pressurized vapor developed behind our brick. Having nowhere else to go, the vapor was being driven into the areas of least resistance which were around our windows and on into the wall cavity. If the windows had been installed perfectly, this may not have been a problem, yet the contractor who installed the windows didn't run a continuous bead (without seams) around the nail flange. We ended up removing brick off the west and south sides of our home and replacing it with vinyl siding since these were the sides of our home that developed problems due to the direction of wind-driven rain and the sun against our home. So, yes there are many factors to consider when there's moisture intrusion. (And by the way, 3 highly respected masonry contractors in our area couldn't find the problem. Each said it wasn't our brick veneer. Yet it was, though primarily from moisture getting through the mortar, no weep holes or flashing, and not having pristine window installation. Our moisture intrusion expert states he has been seeing many homes with similar problems the past few years.)
After selling doors and windows for many years, I find this original post disturbing. Windows and or doors are to be installed per the manufacturers instructions. That's what code reads. There are so many installers that cut corners and create shortcuts. Paying attention to what your builder/architect/supplier is doing is important to the success of your project. If there is something wrong and you're getting water infiltration, there are methods to determine what's happening. If the water is coming from between the glass and the cladding then it may need to be reglazed or apply a cap bead to eliminate the problem. 99.9% of the time water is introduced around the perimeter of the window. Much like what the September poster experienced. I have had extreme success with Eagle products. PAY ATTENTION TO WHAT'S GOING ON. Do your homework, every supplier has problems. People make mistakes. Read the instructions. Window suppliers must provide independant testing of their product for performance ratings. Informed consumers make better decisions.
"I have seen you state the same thing many times over and am curious as to your definition of very long in this statement?
"The whole idea of cladding wood to 'protect it' has never worked for very long""
At least till the mortgage on the house is paid off, so 30 years.
The idea of 'no maintenance' has taken hold so badly it is ridiculous.
If you own a house it requires maintenance.
Perform it or pay the price in the long run.
You can get windows that can be maintained (and then maintain them) or install 'maintenance free' windows and pay for the damage they allow and new windows.
Correctly maintained wooden double hung windows last a LONG time.
One of my houses has many that are over 200 years old.
They have been maintained, and even in most cases improvements have been made including better weatherstripping, improved sash cords, sheet foam insulation in weight pockets.
A few needed some sash parts replaced (PO did not do maintenance on some second story windows).
Alot of the advantages of old wood windows has to do with type of wood used and that they used storm windows that protected them.They also had the advantage of being able to usevery durable lead paints.Most of the wood used in modern windows is ponderosa pine or some other rapid growth species that doesn't hold up as well even after being treated with chemicals.They also had the ability to dry out more due the more airy build of the windows and homes.I do prefer Eagles extruded aluminum vs a rolled form aluminum that leaves a gap such as Pella.More recent woood windows can be difficult to repair due to more complex frame and sash designs and the old ones can quickly be cost prohibited to rehab.Any window will cause damage if not maintained but the older ones typically cause less damage due to the better quality woods used to build, airy nature of older homes,plaster walls ect.
