JOIN NOW LOG IN
Mounting a stained glass window into a double glazed frame
Posted by pjb999 (My Page) on
Fri, Nov 13, 09 at 14:49
I may cross-post this in the stained glass forum, I'm not sure which is best.
We have an older wooden 'feature window' and a friend made us a stained-glass insert to fit inside (there's a rebate there so the edges of the window press up against it, and it's currently held in place with screws) - so the existing double glass is there, then a 3" gap or so, then the stained glass.
There has been quite a lot of condensation between the original window (double glazed, about 20 years old but in good condition) and the stained glass insert. Insert doesn't fit very tightly, I am wondering if I should try and make it LESS tight fitting, so there's possibly more airflow, or should I try to seal it with weather stripping so it's totally airtight?
I could put silica gel sachets in the bottom, wouldn't look great but would be somewhat disguised by the border, or I could turn off the humidifier for a couple of days before I seal it up - we are in a very dry climate and without the humidifier the % RH often drops below 35%.
What is best, does anyone have any ideas?
