Installing windows in cold weather
Posted by cvette (My Page) on
Fri, Nov 12, 10 at 11:13
Hi all, my install was pushed out one week due to the contractor's schedule. Now the weather is expected to be 40-45F during the install but sunny. Do I need to worry about the temperature of the windows during the install? Should they stay in the cold garage until the install so they aren't contracting during installation? Or should I keep them inside until the install?
I'm worried the cold weather might affect the quality of the install...or am I concerned over nothing? Is there a temperature at which it is too cold to install, aside from the contractor's comfort?
Thanks
RE: Installing windows in cold weather
I would not worry about the cold weather until it is going to be real cold, like teens or 20 degrees out. Until them nothing to worry about.
I have the same concern. I'm getting windows installed in 2 weeks and I live in Zone 5. One thing I was told by the sales rep is there is a seal that needs to go around the windows, it sounds sort of like a rubber gasket, and that needs to be at 48 degrees or warmer when installed, however I was told they can be kept inside for a bit before the install to warm them and that should be fine. My other worry is that stucco needs to be used for patchwork on my house. Some stucco manufacturers state stucco needs to be at 40 or higher for 24 hours. I've called 4 contractors here who all said they apply an accelarant to stucco so it dries quicker and it only needs to be above 40 for 4-6 hours. Some companies tape up tarps and use space heaters, or you leave the windows open overnight to keep things warm that first night after the install. I also got their 2 year warrantee on the install in writing just in case the low temps are a problem. Of course the cracking will probably start after 2 years and one week....
I would imagine you don't want sudden temperature changes, so they should acclimatise. Otherwise I'm sure things will be fine.
Well, one window had to be reordered and here it is, 10 degrees outside and my contractor is coming back to install the last window today. What should I be worried about during the cold install? The window is inside at the moment. I figure I'd rather have it shrink when the exterior cools instead of expand when the interior warms.
I do not believe one window will be an issue at all, if this is a normal area that has cold winters I am sure he know what to do if he has been in business for any length of time.
I too am having windows installed within the next couple of weeks, and worry about cold weather installation. I asked the installer what type of caulk he'll use, but he was very dismissive. I'm concerned that the caulk might fail if applied in certain temperatures.
