| I need an education on windows. I currently am in a brick ranch house with ~38 year old, double hung wood-framed Pella windows. These windows have a "storm glass" insert which pops right out on the inside (I am unsure if that is the correct term for it). The glass adds no insulation value beyond whatever dead air is trapped there between the plates of glass. The windows were probably state-of-the-art windows for the 70's and the interior wood is very attractive. Most of the actual wood frames are in good shape but there is/has been some condensation between the glass plates and on some spots on the sills. Additionally, the white wood exterior frames are in need of attention. On the SW side of the house the exterior wood is slightly 'peffy' due to the weather getting through the paint. The sun is rather extreme there.
We are willing to do some refinishing on the interior sills but the thought of exterior window frame painting is painful. I think we are in the market for "replacement windows", BUT...I want an education to see if it is feasible to replace the entire window and not just drop in the typical replacement. Can that be done from the outside without damaging the interior window trim? Or is this the exact reason folks chose "replacement windows"? I'd prefer all new windows but want to keep my interior trim. It may be possible to re-do the interior trim but I can imagine the difficulty of trying to match the warm clover honey finish if the trim is damaged. I would not be fond of losing the current size of the glass and think it might feel somewhat claustrophobic. Drop in windows would also not solve the problem(s)of the exterior white trim (paint and weathered wood)and new caulking.
Understand that the $ involved is always an issue but I would gladly pay more for a better product, proper installation, and a solid warranty. I'd like the windows to be a plus in 20 years and not a minus in 5. I do see a lot of back and forth jibing on the forum about the different brands and selections, and box stores in general. I have no prejudice coming into this purchase and have had great experiences buying things at (mostly) Lowe's and have always been well-treated when I had a problem. I realize that not all box stores or their locations are created equal (but so far no complaints from me). I am certain we would only want wood windows (or replacements). White or other-colored Vinyl is just plain ugly to me. E-value films and gas-filled panes are great IF the warranty is similarly great. We also would prefer if the windows were not excessively smaller (see above). Any answers to the questions are appreciated. Any advice on research or reading materials would also be most welcome. |
- Posted by windowsonwashington (info@windowsonwashington.net) on Tue, Sep 6, 11 at 9:41
| Pocket/Insert type replacements will allow you to keep your interior trim intact without disturbing it. Downside, although most still opt for it because of the cost effectiveness of pocket/insert vs. full tear out, will narrow the amount of visible glass a bit in the process. Most pocket/insert jobs account for cladding or wrapping the exterior trim once it has been repaired. Doing the insert style replacement usually entails ripping off the exterior stop and that will need addressing via clean up/cladding. A wood clad window is going to exacerbate the loss of glass even further as compared to some of the thin vinyl or fiberglass windows out there so be prepared for that. I would recommend a good fiberglass frame in your application. Keep researching your choices and don't count on your vendor to give you the most unbiased information. Keep posting and we will continue to give you feedback.
Return to the Windows Forum
