| I live in an "antique" house, 1790. Wood clapboard siding with board sheathing. There is no house wrap, tar paper, etc. etc. Just siding over boards.
I need to replace a couple of casement windows. What is the right way to flash them? Everything I have read (like this great FH article: http://www.finehomebuilding.com/PDF/Free/021197054.pdf) assumes the presence of housewrap to flash over. Does typar tape even stick to wood? Or should I just caulk the sides and top? What would the flashing even do on my house? Also, what is your opinion of premade sill pans like Jamsill? The FH article uses a beveled piece of siding and flashes over that. Thanks! |
- Posted by windowsonwashington (My Page) on Wed, Aug 26, 09 at 10:41
| Typar tape will not stick well to wood. A good flexible self sealing membrane tape will stick to wood. Pre-made sill pans are nice but are typically used in new construction applications. How much of the siding will you be removing? |
| Thanks, I think that is what I am looking for. I would like to remove as little siding as possible. Obviously I will remove the outside trim, which should give me most of the room I need for the flashing. Worst, case I may have to sawzall a few nails to get the flashing to be wide enough. So something like this: I can use a beveled piece of siding instead and not caulk the bottom of the window. Thanks again! |
Return to the Windows Forum
