| Hello,
I have some new aluminum clad wood windows in my house and I would like to use Waterlox to finish the interior, but I need some instructions on how to accomplish this. Any suggestions? I have never finished any type of wood before. I just need some guidance on how to get this done. Any help would be greatly appreciated. Thanks! |
| Short answer = Take your time. Long answer= Remove sashes from frames, as much as possible remove hardware from sashes. It is best to not remove weatherstrip because it often won't reinstall as nicely as it was installed at the factory. Avoid masking weatherstrip with tape that has an agressive adhesive but by all means try to not get your finish on the weatherstrip. Don't be in a hurry to re-assemble the units. Make sure the finish is completely dry to the touch before closing the windows against weatherstrip. Do not wipe the weatherstrip with any solvent of any kind. The only lubricant or cleaner I recommend on window weatherstrips is Lemon Pledge. It will also be kind to your wood finish. The most common service calls and long-term issues with wood clad windows relate to how carefully the finishing of the wood is done. You will enjoy your windows for a much longer time than it will take to finish them, so take your time and do it right. You will never regret taking the extra time. |
Return to the Windows Forum
