cost tor reduce size of fireplace mantle
L A
REMODELING GUIDESUnique Chimneys, Outside and Inside
Chimney placement, style and materials can make a big impact on a home's design
Full StoryGREAT HOME PROJECTSHow to Remodel Your Fireplace
Bring your fireplace design up to snuff with this makeover lowdown
Full StoryFIREPLACES12 Hot Ideas for Fireplace Facing
From traditional brick to industrial steel, there’s a fireplace cladding here to light up your design
Full StoryLIVING ROOMSHow to Convert Your Wood-Burning Fireplace
Learn about inserts and other options for switching your fireplace from wood to gas or electric
Full StoryLIVING ROOMS8 Reasons to Nix Your Fireplace (Yes, for Real)
Dare you consider trading that 'coveted' design feature for something you'll actually use? This logic can help
Full StoryDECORATING GUIDESMantel Makeover: From Builder's Grade to Live-Edge Wood
See how an all-wrong mantel became a gorgeous fireplace focal point at the hands of an interior designer and her carpenter
Full StoryFIREPLACESWhat to Do With That Fireplace You’re Not Using
Make the extra space work for you with artfully arranged logs, books or decorative objects
Full StoryMOST POPULARHow High Should You Mount Your TV?
Today we look at an important question to consider when locating your television: How high should you set it?
Full StoryWORKING WITH PROSHow to Commission Custom Wood Furnishings
Can't find just the right table, shelf, desk or what have you? It's woodworkers to the rescue
L AOriginal Author
Windows on Washington Ltd
Brighton Window Contractors · Ocean Pines Window Contractors · Payson Window Contractors · Revere Window Contractors · Portage Window Contractors · 63040 Window Contractors · Central Islip Window Contractors · Muttontown Window Contractors · University Window Contractors · Queens Interior Designers & Decorators · Van Wert Interior Designers & Decorators · Great Falls General Contractors · Marinette General Contractors · Brookfield Carpenters · Palmetto Bay Carpenters
