Fri, Jul 23, 10 at 9:01
| I plan on replacing old double-hung windows and sliding doors with same sized new Marvins or Andersen 400s. The house has wood clapboard siding. What do I need to know to figure out which contractor would do the best installation? I've gotten burned by roofers and tilers that came recommended so I prefer to know what constitutes a quality job to help weed the clowns from the craftsmen. Are manufacturer's installation instructions complete in their detail from start to finish? Would a contractor experienced with Andersen products have any problems installing Marvins? |
- Posted by windowsonwashington (My Page) on Fri, Jul 23, 10 at 18:03
| You need to first determine how would like to have the windows installed. Given that the home has wood clapboard siding, I don't foresee you wanting to undertake a siding replacement. That rules out a new construction installation. Insert windows can be the most straightforward or most complicated process depending on the competency of the contractor. A competent contractor should have no problem regardless of the window used. Go look at work examples. The skill is shown in the details. |
Return to the Windows Forum
