| I asked for an estimate for faux wood blinds for 2 windows. I can't find the exact measurements now, but I think they're 72 inches wide and about 24 inches high. now they're telling me faux wood isn't suitable. two questions: 1) is faux wood unsuitable b/c of the width (as he says) and 2) is this a good estimate for reall wood? thnaks very much. terry
here's the estimate I got: fter looking at the photos and the sizes I do not recommend a Faux Wood blind, the slats on a Faux blind are all polymer and have a tendency to bow at widths grater than 36"
- Posted by GulfBreezeWindows (andrew.poole@gulfbreeze-windows.com) on Thu, Jul 21, 11 at 11:42
| If your height is only 24", you shouldn't have a real problem. You will however have more vertical lifts in a Faux wood product than Real wood at anytime because of the weight. As far as a price goes, I would definetly look around as those price seem really high. Keep in mind different areas have different mark ups, I just think you may find better. |
| I forgot to put in the measurements: the windows are 26 1/4" by 77 1/4 inches (outside mount) or 21 1/4 by 72 1/4 (inside mount) thanks, t |
- Posted by GulfBreezeWindows (andrew.poole@gulfbreeze-windows.com) on Tue, Jul 26, 11 at 10:02
| If your height is 77" then I would lean towards wood just based on the fact that lifting 77" of Faux is going to be heavy. Also, I still think you should look around for better prices. |
Return to the Windows Forum
