Glass/Screen Door
Posted by chedanemi (My Page) on
Sun, May 2, 10 at 18:43
I know this is a windows forum, but I guess the concept is similar! My front door faces directly south and is a painted steel door with a fiberglass frame around the window in it. The fiberglass frame is unpainted. The problem is, my current storm door is solid glass, and with the direct sun coming through the glass, the interior door get so hot you can't touch it. Plus, some of the sealer is beginning to leak around the door window frame.
My question is: is there a door made from double pane or some type of glass which will not allow the heat to come through so strongly? I've asked a couple sales people, and no one seems to think there is a solution.
Any help is much appreciated!
RE: Glass/Screen Door
Storm doors are typically single pane glass so low-e glazing is out of the question. You might look into an applied glass tint, a newly constructed porch or a large tree etc.???
Storm doors are designed to be removed in the summer months.
Although they do make 1/1 insulated glass panels for storms doors, your door is still going to cook.
Did you ever put your arm down on your car in the sun? Hot!
I believe your only solution is to replace the inside 1 3/4" steel door with a fir wood door. It won't get hot.
The Porch Guy
Here is a link that might be useful: My Album
What color is your inner door painted, if it is a dark color that will be a good part of the problem. Try a light color and see if this helps. Most door manufacturers will tell you not to paint a steel door a dark color if it is exposed to a lot of sunlite especially if you use a storm door
