How to select a product to seal a gap between a window and wall
Posted by coody (My Page) on
Fri, May 27, 11 at 1:02
Hello! I am confused by many different types of sealant such as acrylic, silicone, caulk and so on. I saw four different products in the HD. Can you tell me which one is the best to fill a gap between a exterior window and wall? It should be weather, water and shrink proof, right? Should the material be flexible or not? Can you help me to select the right product? Thank you.
RE: How to select a product to seal a gap between a window and wa
Use "Great Stuff" from Orange to fill a gap between the window and the wall. It's low expanding foam and won't buckle the frame if you are sealing a vinyl window. Then I would use quad caulk to seal the window perimeter.
"I saw four different products in the HD"
Only four?
You must not have looked very hard.
There are at least 50-60 in the HD nearby, let alone the Lowe's down the block.
Low expanding foam for any gap over more than about 1/4 inch to avoid the expanding foam forcing the window out of square/plumb.
The interior window trim (casing) should cover the foam for a finished appearance.
If you do not have any trim the wall material (drywall. blueboard, etc.) should be covering it.
I have never thought about the expending foam. Is that material flexible, shrink proof? Why is it better than the GE silicone II, by the way?
"I have never thought about the expending foam. Is that material flexible, shrink proof?"
Once it sets up after expanding it is not going to shrink.
"Why is it better than the GE silicone II, by the way?"
Because it expands to fill the entire gap completely.
U=You are likely to need to come back after it hardens and cut off any that is above the surface.
If the gap is directly against a window jamb be sure to use the LOW expanding foam.
The high expansion stuff can exert enough force to bend the window jamb and interfere with the movement of the sash.
Silicone seal is expensive and overkill for routine weather sealing.
