Sat, Apr 16, 11 at 23:45
| I have 2 sets of windows (3 adjacent double hung, and 3 adjacent double hung with 3 transoms). They are not factory mulled. They are anderson 400 series. The space between the windows is 5 inches which would work well to run back to back 2.5" colonial casing between all the windows/transoms. The problem is that all of other windows in the house and room are with 3.5" colonial casing. My only other option I have in mind is to run flat trim board in between all the windows. At 5" wide it could look dull, also it would need to be only 1/4" thick, I'm not sure if this is a common trim board thickness.
The walls are plastered around and in between the windows flush with the face of the windows. Any suggestions on how to trim and interesting profile in between these windows? |
- Posted by millworkman (millwork4u@gmail.com) on Sun, Apr 17, 11 at 9:10
| The only thing I could think of is to use flat material and add trim pieces to it to make a raised panel effect. |
| I'm not sure I understand what you're looking for - if you could post a picture that might help. What about taking 3.5inch casing and cutting off one inch of the outside - and then butting the two cut edges together? Depending on where the cut ends up on the profile that might work? |
- Posted by matthew1222 (My Page) on Wed, Apr 20, 11 at 7:53
| dennisgli, you suggestion looks really nice, I just made some test pieces. Thanks! |
Return to the Windows Forum
