| So I'm doing some painting at our summer home once the weather gets a bit warmer, and I'm noticing that one of my storm windows needs work. It's pretty permanently affixed at the moment, summer and winter, so we'll be painting with it installed.
From a distance it looks like this: Not too bad. But when you get close, there's some deterioration around the trim (if that's the word, I'm new at this). Also the window sills and the area below need to be painted, obviously, but I'm concerned about the window itself. I've done a bit of exterior painting but not around windows. So I guess the question is how to attack this. I'm pretty new to this, so any suggestions would be appreciated. Thanks. |
| read this site...that isn't "trim" but glazing compound which holds the glass in place... before painting the wood trim, remove any peeling or flaking paint...diy has pointers on that, also... |
Here is a link that might be useful: http://www.diynetwork.com/how-to/how-to-repair-and-repaint-old-window- sashes/index.html
| Time for major window work if you want to refurbish them. The sashes need to come out, the glass needs to come out, then be bedded and glazed again. While the glass is out you can scrape the rest of the sash, repair any open joints, and then prime and paint. |
Return to the Windows Forum
