Replacing all windows, is this too expensive??
justnotanotherguy
12 years ago
CONTRACTOR TIPSThe 4 Potentially Most Expensive Words in Remodeling
‘While you’re at it’ often results in change orders that quickly add up
Full StoryREMODELING GUIDESReplace vs. Restore: The Great Window Debate
Deciding what to do with windows in disrepair isn't easy. This insight on the pros and cons of window replacement or restoration can help
Full StoryReplace Your Windows and Save Money — a How-to Guide
Reduce drafts to lower heating bills by swapping out old panes for new, in this DIY project for handy homeowners
Full StoryDECORATING GUIDESQuick Fix: Find Wall Studs Without an Expensive Stud Finder
See how to find hidden wall studs with this ridiculously easy trick
Full StoryGREAT HOME PROJECTSHow to Replace Your Lawn With a Garden
New project for a new year: Lose the turfgrass for energy savings, wildlife friendliness and lower maintenance
Full StoryMOST POPULARKitchen Evolution: Work Zones Replace the Triangle
Want maximum efficiency in your kitchen? Consider forgoing the old-fashioned triangle in favor of task-specific zones
Full StoryHOUSEKEEPINGAll Together Now: Tackle Home Projects With a DIY Co-op
You're in good company when you pair up with a pal to clean, organize, repair and replace
Full StoryWINDOWSHow to Replace Window Trim
For finishing new windows or freshening the old, window trim gives a polished look with less effort than you may think
Full StoryGREAT HOME PROJECTSHow to Replace or Revamp Your Garage Doors
Boost curb appeal and maybe even security with new garage doors. Find out cost ranges and other important details here
Full StoryFURNITUREOld Furniture: Clean, Reupholster or Replace It?
A veteran upholstery cleaner weighs in on the options for found, inherited and thrift store furniture
Full StoryMore Discussions
WindowDog
millworkman
Wilmington Window Contractors · Dracut Window Contractors · Hammond Window Contractors · Opa Locka Window Contractors · Woodland Hills Window Contractors · Struthers Interior Designers & Decorators · Bowling Green General Contractors · Eatontown General Contractors · Great Falls General Contractors · Keene General Contractors · Valle Vista General Contractors · Carlsbad Carpenters · Fair Oaks Carpenters · Kissimmee Carpenters · Tucson CarpentersEast Bay 10
Windows on Washington Ltd
justnotanotherguyOriginal Author
millworkman
HomeSealed
toddinmn
millworkman
