Sun, Mar 28, 10 at 18:22
| Hi. I bought my condo a couple of years ago. First I noticed bubbles in the paint around the windows...then the plaster started cracking...like the drywall kind of opened up and started crumbling out...now there is mold around the windows, particularly on the windowsill. Do I need new windows? A window repair? The exterior of the building is brick....Thanks to ANYONE who helps...I rent this place out and I can't get new tenants in until I remedy this problem! Thanks! |
- Posted by windowsonwashington (My Page) on Mon, Mar 29, 10 at 7:57
| You need to get someone to the home who understands water infiltration. Most often times, if the water is coming from around the connection between the window and the wall, the leak is between the window and the wall on the exterior. Most times. Depending on the where the windows are located in the home, there is also the potential of a roof source of moisture. This is impossible to diagnose via the internet. You need to get someone who know leaks out to home and get the issue repaired right away before you cause significant damage to the home. |
Return to the Windows Forum
