| Across the front of my home I have 3 huge floor to ceiling picture windows. The middle one just today began showing the dreaded condensation inside the window. Just the mist; no water yet, because it's just started. I replaced all 3 windows with Low E windows about 10 years ago....so, I'm very disappointed that one of the seals is no longer working, allowing the build-up of condensation.
I hate throwing away perfectly good glass, and did some search about alternatives and saw Crystal Clear windows that removes the moisture. Here's a link to its website, explaining the process. My search of the windows forum hasn't revealed anyone who has tried this approach to resolving a leaking seal. I do think this approach will be best used in a newly leaking window, where there is very little build-up of moisture. Have any of you tried this? Also, what is the "normal" life of large windows before the seal becomes compromised. I would hate to think 10 years is "normal".....That's pretty expensive, and environmentally wasteful. Thanks, in advance, for your responses. |
Here is a link that might be useful: Crystal Clear Windows
- Posted by windowsonwashington (info@windowsonwashington.net) on Fri, Mar 2, 12 at 23:21
| Can't do it on a window with tempered glass like you should have in those units anyway...at least via the typical means that are listed. |
Return to the Windows Forum
