| If you’re a homeowner with even modest skills, the only things you need to restore lightly scratched windows, tabletops, mirrors, auto glass or even headlights like a pro is a bit of Cerium Oxide, a felt buffing wheel and an electric drill to attach it to. If you have grime on your glass or stains on a shower door caused by hard water and they don’t come off with household cleaners, Cerium Oxide will take care of the problem. First of all, what is a “light” scratch? If you can distinctly feel a scratch in your glass with a fingernail, it may be too deep to polish out and the risk of trying to do so yourself is probably not worth it. However, if you have a hazy mass of shallow scratches or scuff marks, it’s Cerium Oxide to the rescue. Cerium Oxide Powder and a felt buffing wheel (3" in diameter) are readily available online. 8 OZ of Cerium is usually plenty for any around-the-house glass restorations. And get the lowest-priced powder you can find, since glass is soft and doesn't require super pure cerium oxide. Here’s how to remove those scratches and stubborn stains in your glass. • Clean the area you’re going to work on thoroughly That’s all there is to it. And don’t throw out any leftover slurry, since it can be stored until dries out and then re-activated just by adding water. Happy polishing! |
| " auto glass" Just watch out for tempered glass. If you polish past the temper layer it instantly shatters into crumbs. |
- Posted by HomeSealed (My Page) on Thu, Mar 7, 13 at 14:12
| I have used a buffing compound called "rare earth" that works very well. Not sure if it is the same active ingredient. One word of warning to reinforce what is a "light scratch" though. If you can catch in it with a fingernail, you'll likely distort the glass before you get the scratch out. |
| HomeSealed, Cerium Oxide is widely used for grinding and polishing glass and since it does fall into the rare earth category, it is very possible (likely) that you are using it as a buffing compound. The very finest grade of cerium is reserved for applications such as grinding and polishing high end telescope lenses and it is eye-openingly expensive.
- Posted by windowsonwashington (My Page) on Sun, Mar 10, 13 at 10:01
| LMAO!!!!! Dude, I never wear a tie except to weddings and funerals! |
- Posted by HomeSealed (My Page) on Sun, Mar 10, 13 at 17:21
| LOL! I love the watch. @ Oberon, good info, as always. I used to do a lot of custom cut glass (mostly laminated) in heavy machinery (cranes, front end loaders), auto, ect, and the buffing compound came in handy on many occasions... Never did check the "ingerdients" though, lol. |
- Posted by windowsonwashington (My Page) on Mon, Mar 11, 13 at 7:46
| The watch does put it over the top. Nobody wants to know of your past criminal enterprises HS...I kid...I kid. I joke with you!!! |
| the watch is classic!! HS, did you cut the glass yourself? |
- Posted by HomeSealed (My Page) on Tue, Mar 12, 13 at 7:41
| Yes sir. Typically on site.... The worst was when you'd get a complicated piece with a bunch of angles or curves and then break it on the last cut. Happened once or twice, lol. Generally we were getting them out of 4x8 sheets of lami. |
Return to the Windows Forum
