Repair lightly scratched glass of any type
Posted by gordonglasscompany (My Page) on
Wed, Mar 6, 13 at 16:19
If you’re a homeowner with even modest skills, the only things you need to restore lightly scratched windows, tabletops, mirrors, auto glass or even headlights like a pro is a bit of Cerium Oxide, a felt buffing wheel and an electric drill to attach it to.
If you have grime on your glass or stains on a shower door caused by hard water and they don’t come off with household cleaners, Cerium Oxide will take care of the problem.
First of all, what is a “light” scratch? If you can distinctly feel a scratch in your glass with a fingernail, it may be too deep to polish out and the risk of trying to do so yourself is probably not worth it. However, if you have a hazy mass of shallow scratches or scuff marks, it’s Cerium Oxide to the rescue.
Cerium Oxide Powder and a felt buffing wheel (3" in diameter) are readily available online. 8 OZ of Cerium is usually plenty for any around-the-house glass restorations. And get the lowest-priced powder you can find, since glass is soft and doesn't require super pure cerium oxide.
Here’s how to remove those scratches and stubborn stains in your glass.
• Clean the area you’re going to work on thoroughly
• Get two small plastic tubs, a pint to a quart in size and fill one halfway with water
• Place the buffing wheel into the water to let it get thoroughly damp, but not dripping wet
• Scoop a couple TBSP of Cerium Oxide into the other tub and add a splash of water
• Use a plastic spoon or knife to stir the mixture and keep adding small amounts of water until the slurry reaches the consistency of heavy cream. (It’s perfectly safe to check with your bare finger. And don’t worry if there are small particles that don’t completely dissolve.)
• Attach the dampened polishing wheel to your electric drill and dip it into the slurry
• Place the polishing wheel on the work area and rev up your drill
• Keep the pad moving constantly side to side and in a circular motion
• Keep buffing until the slurry is ALMOST dry (CAUTION: Be sure not to buff the glass when it is dry. This can cause the glass to overheat and crack.)
• When the slurry has dried, wipe it off
• If the glass has not been cleared up to your satisfaction, just repeat the buffing process with the slurry-dampened pad
That’s all there is to it. And don’t throw out any leftover slurry, since it can be stored until dries out and then re-activated just by adding water. Happy polishing!
RE: Repair lightly scratched glass of any type
" auto glass"
Just watch out for tempered glass.
If you polish past the temper layer it instantly shatters into crumbs.
I have used a buffing compound called "rare earth" that works very well. Not sure if it is the same active ingredient. One word of warning to reinforce what is a "light scratch" though. If you can catch in it with a fingernail, you'll likely distort the glass before you get the scratch out.
HomeSealed,
Cerium Oxide is widely used for grinding and polishing glass and since it does fall into the rare earth category, it is very possible (likely) that you are using it as a buffing compound.
The very finest grade of cerium is reserved for applications such as grinding and polishing high end telescope lenses and it is eye-openingly expensive.
In the effort of keeping up with my cat dominance...I found a picture or Oberon cat.
LMAO!!!!!
Dude, I never wear a tie except to weddings and funerals!
LMAO!!!!!
LOL! I love the watch.
@ Oberon, good info, as always. I used to do a lot of custom cut glass (mostly laminated) in heavy machinery (cranes, front end loaders), auto, ect, and the buffing compound came in handy on many occasions... Never did check the "ingerdients" though, lol.
The watch does put it over the top.
Nobody wants to know of your past criminal enterprises HS...I kid...I kid. I joke with you!!!
the watch is classic!!
HS, did you cut the glass yourself?
Yes sir. Typically on site.... The worst was when you'd get a complicated piece with a bunch of angles or curves and then break it on the last cut. Happened once or twice, lol. Generally we were getting them out of 4x8 sheets of lami.
