Jeld Wen Siteline EX, Lincoln or Sierra Pacific double pane?
Posted by Junepo (My Page) on
Sat, Mar 9, 13 at 2:23
All windows are aluminum clad and wood inside with divided line. And I plan to use 1 1/8 mullions. But which brand is better: Jeld Wen, Lincoln or Sierra Pacific?
RE: Jeld Wen Siteline EX, Lincoln or Sierra Pacific double pane?
Those three are all below average at best in my opinion. Which one is best of this lot, don't really know what to say to that without more information. What type of window and quantity are you using, where your building and what are your expectations of these windows and lastly what your budget is? 1 1/8" muntins (muntins is the correct term as mullion is typically the process of joining units together) do not tell us anything, are these grids, simulated divided light, true divided light?
not a fan of those choices either. IF you must chose from those, maybe the Jeld-Wen Siteline, which uses extruded clad vs. the weak roll form clad that others use to keep the cost down might be a positive point. IF you could, take a look at the Marvin Integrity.
Listen to MWM...he knows wood windows like it is his job (HA!).
No...in all seriousness, MWM knows his stuff when it comes to wood. I would listen to his advice very carefully.
