Window estimate
Posted by brer (My Page) on
Thu, Feb 14, 13 at 19:56
I'm interested in having a wall air conditioner installed in the same room that I have three old large picture windows with awnings at the bottom. There are three more in the living room adjacent.
I got an estimate for a Panasonic KS24NKU which would need a new electric line put in, and siding repaired around the opening. The windows would be vinal picture windows with awning bottoms.
The estimate was for $17,000. Doesn't this sound a little high?
I live on Long Island, and my oil bill is about $700 in the winter months, probably losing some of the heat to these windows.
Any suggestions, or warnings.
RE: Window estimate
What is the $17,000 estimate for? Read your questions, you give us ZERO information.
RE: Window estimate
So you have 6 sets of pw/awn combo units for 12 total units. Then, you have a cut-in AC unit being installed, including the electrical lines and everything?
As MWM said, there are way to many details missing here to say if that is high or not. In addition, I have no clue what an AC unit like that costs.
What I can say, is that the windows should probably run somewhere between $500-$900 per unit (x12) depending on options, install circumstances, etc. Could be more if they are loaded up with options, full frame tear-outs, etc, but for normal circumstances, I wouldn't expect that the window portion would account for more than maybe $10k on the higher end.
My suggestion: get a couple more quotes. That will be your best way to compare.... Then come back here and present more details on the products, install, etc, and we can give you some direction on what might be the best choice. :)
