Need Advice For Fun Framing Project - liberating stained glass
Posted by Jackson23 (My Page) on
Sat, Jan 1, 11 at 20:30
Hi,
There is a window on our house that an earlier owned decided to cover up in order to create a wall to put cabinets and run stove ventilation. It is an upstairs apartment, and recently we decided we'd like to allow that light in. After a bit of work figuring out where the window would be located, we did manage to open up the wall. I had to cut through a 1/2" layer of drywall, then take out the fiberglass insulation, and finally cut through a 1/4 inch layer of plywood (very carefully so as not to crack the stained glass!).
I must say, it was an exciting process, and a bit scary knowing full well it could be a can of worms to open up the wall since you never really know the exact reasons why previous owners do things. At this point, I have to say we are extremely happy so far with the decision, a ton of character was gained by liberating this window to give it life from the inside. I'm including a few pics so you can see for yourself. The window itself is rather large, I estimated it at around 64" wide by ~36" from top to bottom.
I am now in the process of making decisions regarding what to do next with how we need to finish it off from the inside. The kinds of decisions we need to make are as follows:
1) The inner glass selection and where to add it (could add it closer to the stained glass or closer to the drywall). We need to protect the stained glass window from the inside, and also provide some kind of thermal barrier. I have no idea whether adding a single pane of glass is enough, I imagine not. For this size of window though what is enough? Double paned, triple paned? You can definately feel colder air there, and we want a thick enough protection so that it would be very very hard for a tenant to break it from the inside. Also what are the proper vocabulary terms for the kind of window we'd be looking for (non ventilated, just for the added light - as a protection and thermal barrier)? Finally what is the best way to install this "inner glass"?
2) Whether to leave the vertical studs in place or whether to open it up for full view. Money is also a consideration and I know the larger the glass the more expensive and also harder to work with. Ideally it would be wonderful to have the full view unobstructed, but I was thinking we may have to construct one or more vertical braces depending on cost and what is the best protection method. They wouldn't necessarily have to be in the exact location that the studs are currently, I don't believe those are load bearing, pretty sure they were erected mostly to hold the insulation in place. Either way, I'm sure we'll end up building a frame around the edges of 2x4's and whether we need any vertical ones in the middle is yet to be decided...any ideas?
3) how to close off the sides and tops of the space between where the drywall is on the inside wall and where the stained glass is. Not sure if this is clear enough, but the walls are fairly thick. For ease of visual image just look at your nearest door frame, theres about 3-4" of thickness in most doors. That "space" from our drywall to the window is roughly 10-12 inches. I was thinking of just adding some dark stained wood on the left, right, and top exactly flush with the wall so I can add trim along the outside. Along the bottom I'm thinking about adding a routed board, so that the tenant would be able to use the sill as a shelf for small plants. A shelf along the bottom would be nice, but then again, would encouraging tenants to set things up there be asking for trouble?
3) other considerations that apply to the above would be constructing this finished area in a way that will allow us to have access to clean the stained glass between tenants if need be (no adhesive glue). We'd like it to be a balance of hard enough to get at so that tenants won't open it up to mess with it
Have no experience installing windows, much less with stained glass so your advice/ ideas are much welcomed!
RE: Need Advice For Fun Framing Project - liberating stained glas
I would copy this post to the forums at oldhouseweb dot com. There are folks over there who have tackled this very project.
You are in more need of a framing contractor. There is no reason that wall cannot be opened up for a full interior view of that window and it is yet to be determined if that interior wall is load bearing or if the load is carried across the outside brick wall.
It also appears that there is an exterior storm of some type on that window already.
If that is the case and you want to appreciate the appearance of the window from inside the home, I would not put another storm sash on it. The reality is that there is a whole boatload more energy leaving that home right now from places other than around the window.
If the window is air tight, that is the largest part of the battle.
Based on the icing on the roof and snow melt, there is considerable more potential in weatherization of the attic and other envelope improvements.
This project is taking forever, but it is moving. We got the window out, I tried to pay someone else to reglaze but it was cost prohibitive so I am doing it myself. Stripped / sanded off all the stain, polyurethane & paint. Got all the old glazing out, and replaced the broken glass with new glass.
I am now trying to figure out what kind of glazing to use. Everything I've picked up says not recommended for stained or leaded glass. I was told by the stained glass store that this is not leaded glass, but I'm building this sucker up from scratch and want it to last 15-20 years if possible so the wrong kind of glaze would really suck. I have DAP 33 (can), DAP 33 (latex based in tube), a sherman williams store glaze. How do people glaze stained glass and what should I do in this case? My window is primed and ready to go! Please help : )
