metal frame swing redo
lori022
9 years ago
Featured Answer
Sort by:Oldest
Comments (9)
carolssis
9 years agolori022
9 years agoRelated Discussions
Using an old swing set frame for cucs next year?
Comments (5)Lead paint was banned for residential use in the US in 1978 and phased out of use in many other areas soon afterwards. I don't know for sure if that would affect outdoor swing sets but I doubt a 20 year old set would have lead paint on it. Power sanding is not a good idea either way. If there is anything harmful in the paint it would end up in your soil and be much more available to the plants than if it were on the swing set. Plants aren't going to be absorbing chemicals from intact paint through above ground parts. Just a bit of info about working with lead paint....mostly you don't want to have paint dust swirling about. Info from Wikipedia: "Working in a lead-safe manner means avoiding dry sanding, dry scraping, removing paint by torching/burning, the use of heat guns over 1100 °F, machine-sanding or grinding without HEPA filtered dust collection or HEPA-filtered vacuum. These methods are now prohibited by the United States Department of Housing and Urban Development (HUD) because they have been proven to create significant levels of lead dust during remodeling, renovation and painting. They must be avoided, especially in properties where children under age six reside. Adult workers using unsafe work practices or improper protective gear may also become lead-poisoned. I would use the swing set as is. It could be rigged up to be a great trellis....See MoreOld Paint on Metal Window Frames
Comments (3)To avoid scratching it, do not use any abrasive materials. Try acetone in a hidden area. It may soften the paint enough to remove it with a pliable plastic scraper. Michael...See MoreChanging the swing direction of a door?
Comments (3)You don't need to replace the door at all, like handymac says - if the door is plain, ie not panelled, you could just flip it end-for-end then it's oriented the right way. Any competent handyperson can rehang a door, I've lost count of how many I've done....you need a helper to hold it, basically hold it in place and mark on the frame where the hinges go. Don't forget to allow clearance top and bottom, I've also found a chisel or screwdriver with a block of wood under, is a handy fulcrum to lift the door (using your foot) to where it needs to be. Just some wood filler on the old hinge spots etc and you're done. You need a hammer, mallet and chisel, that's about it...oh plus a drill and appropriate hardware to redo the door lock if you need to. If the door's panelled, you need to spin the door 180 degrees, so you'll need to swap the hinge to the other side of the door, and reverse the lock....See MoreSalvaged yard swing
Comments (14)after stressing out for the last year after our dog turned our cushions to July Snow in the yard, I tried all kinds of plans, WM had the fabric but not the foam, the cushions there didn't fit well, couldn't find foam on line for less that $60 each, I came upon the idea of getting two chaise lounge (3 even sections) cushions, and centered one on the back and tucked the outside ends to a curve, and placed the other one on the seat centered. The extra length on next to the arms gave it just the comfyness it needed. I am so PLEASED- I did a little dance in the yard. My son thought I had lost my mind. Now I take them inside and can take my little catnaps once again......See Morerosiew
9 years agonicole__
9 years agolori022
9 years agonicole__
9 years agoconcretenprimroses
9 years agoNeual Waters
7 years ago
DIY PROJECTSReinvent It: A Houzzer Turns Thrifted Pieces Into a Swinging Daybed
Snuggle up on this delightful porch piece and you'd never guess it's made of salvaged scraps
Full StoryFURNITUREObjects of Desire: Indoor Swings for Flights of Fancy
Prepare for liftoff — and a whole lotta fun — with chairs, benches and hammocks suspended from the ceiling
Full StoryBEDROOMSGet in the Swing of Things With a Hanging Bed
Give your bedroom a style lift with a fully or partially suspended bed — or one that just mimics the look
Full StoryDECORATING GUIDESSwing for the Fences With Baseball Decor
Show major-league style with artwork, memorabilia and other baseball-theme elements that are fan-tastic
Full StoryBATHROOM DESIGNHow to Mix Metal Finishes in the Bathroom
Make a clean break with one-dimensional bathroom finishes by pairing nickel, silver and bronze hardware and fixtures
Full StoryREMODELING GUIDES5 Places to Love Corrugated Metal in Your House
It’s budget friendly, versatile and even colorful. Is it any wonder this popular exterior material is making inroads indoors?
Full StoryPRODUCT PICKSGuest Picks: A Mix of Metals for the Home
Add a dash of shine to your rooms with these 20 metallic furniture, lighting and accessory options
Full StoryWINDOWSFrame the View with Divided-Light Windows
Multi-pane windows add architectural interest to rooms of any style
Full StorySMALL HOMESRoom of the Day: Living-Dining Room Redo Helps a Client Begin to Heal
After a tragic loss, a woman sets out on the road to recovery by improving her condo
Full StoryTRADITIONAL HOMESHouzz Tour: Redo Brings a 1720s London Home Into the Present
Skillful renovation and an eclectic mix of art, antiques and furnishings update an 18th-century townhouse
Full StorySponsored
nicole__
