Thu, Dec 10, 09 at 17:33
| i have a question...i used the GE silicone to glue some marbles and rhinestones onto a hard plastic cutting board. the rhinestones seem to stick fine but the marbles came off like they were stuck on with a very flexible rubber cement,, just peeled right off,, what did i do wrong or what adhesive should i use on that type of surface |
| Did you clean everything real good before applying glue? I sometimes use alcohol to wipe things and let it dry and then glue. There is no other reason that I can think of that would keep the marbles from sticking. Also its better to let things set up for at least 24 hours before messing with it. Hope this helps. Donna in Florida |
