Tutorial 4 craftylady morton diamonds
Ok here goes...I am not a teacher but I will try!!!! This will be for a 60 degree diamond.
1. I am assuming you already have your strip of glass cut..if not cut a strip of glass to your desired width. Your bar lock will go into hole 16 on the right side of the cutting bar. To do other angles look on page 5. of your booklet
2. You need to cut a piece of scrap off the glass to make your first 60 degree angle. DONT THROW THIS PIECE AWAY. I have marked my piece with a "T" so you can see where the top is.
3. Now this is the tricky part..turn the piece of scrap over, bring down the cutting gauge on the cutting bar and place the glass as shown. You can now see the "T" through the backside of the glass. Place your Glass stop in the hole closest to the piece of scrap and tighten down so the scrap is sitting against the glass stop and against the cutting gauge. Move cutting gauge back up to top of the cutting bar. Remove piece of scrap glass.
4. Put your strip of glass back under the cutting bar, with first 60 degree angle facing to the left. Cut your first diamond. If the first diamond placed on the glass strip (sorry no pic for this) is wider adjust the glass stop to the right. If the strip is wider adjust to the left.
I hope this makes it a little clearer!!!!!
chickeemamaOriginal Author
bamasusanna
Everett Window Contractors · Houston Window Contractors · Naples Window Contractors · Yeadon Window Contractors · Struthers Interior Designers & Decorators · Schiller Park Custom Closet Designers · Chula Vista Custom Closet Designers · Indianapolis Custom Closet Designers · Mount Pleasant Custom Closet Designers · St. Louis Custom Closet Designers · Vista Custom Closet Designers · Camp Springs Custom Closet Designers · Atlantic Beach Window Contractors · Piedmont Window Contractors · Surfside Window Contractorsshrty411
rosemarythyme
nicethyme
texaswild
nicethyme
haziemoon
barbfrizzell1955
barbfrizzell1955
d3bbi
shrty411
barbfrizzell1955
shrty411
lyndalu
Shades_of_idaho
bamasusanna
Shades_of_idaho
