Table
Posted by larke (My Page) on
Sun, Jul 25, 10 at 13:13
Hi, I have an old piece of stained glass (from a larger window) that I want to put into a coffee table with a light underneath. I don't have a particular table yet, but I know I want the light not to be very bright, not strong, just enough to make the point and I don't know how to set it up. Would an LED light be too strong and/or focused at one point (thinking of using one because it would last a long time) or should I use something else? Is there any way to do it without electric cords being involved? Basically, anyone have a clue where to start? Thank you!
RE: Table
what about using those no flame candles? they even have them that change colors to add drama??? Just a thought
RE: Table
Thanks, but a) I have no idea what those are, b) I'd like something that can be turned on whenever I like and stay on (til I turn it/them off). Somehow the idea of candles (unless I'm wrong about those) sounds very impermanent and that it might end up being 'flickery', which I'm not really interested in.
RE: Table
If you use one light you will get a bright spot no matter what. depending on how you make it-rope lighting is a good bet or led light bars set into the edges under the piece. You also need to have a good bright white reflective surface to evenly diffuse the light back up into the stained glass. Do a google search for "light box" these are used by glassers to cut glass. your table will have to incorporate this general idea to do what you want it to. Good luck!
RE: Table
Thanks - I discovered light boxes today and will look into them (not cheap!), thanks again. I also might do something with mirrors.
What about Christmas lights?
I've made glass block lights with stained glass on the outside and christmas lights on the inside and the light looks pretty even to me. Also, they are a cheap/easy thing to experiment with first.
RE: Table
Yes I was going to say christmas lights either the small ones or the large ones. Also you will need some kind of support for the glass or it will sag in the middle depending on how big it is. You could build or buy a shadow box put the stained glass on top & lights inside. i have seen tables like this where you can put things inside to show.
Good luck.
