Fri, Jul 4, 08 at 5:41
- Posted by slowmedown (My Page) on Fri, Jul 4, 08 at 7:24
| OH MY WORD!!! That is sooooo beautiful! Haven't done an indirect method yet, but I think most people use contact paper. Think the contractor's paper - heavy craft paper w/work also. I use it a lot for making patterns. It's quite sturdy, so I think it w/work fine. Wonderful project. You did a beautiful job. Welcome to the forum. Keep us posted on the extension. |
| Thanks, slow. Wouldn't using contact paper pull the glass pieces from the thin-set when peeled away? I thought I needed to use something that would allow water to dissove the glue that held the glass pieces to the base, no? |
- Posted by shrty411 (shrty411@hotmail.com) on Fri, Jul 4, 08 at 9:36
| I think if you wait until it has cures enough the glass won't pull away. I haven't done it though, so I'm not sure. the contract paper should work fine |
| when they show contact paper in use, its always noted that they don't pull it up but peel it sideways or low. I would go with Slows suggestion of the brown kraft/construction paper so that you can draw right on it. Thats very nice btw, love the design! |
| I agree with Slow that a brown type paper should be used. Useing a water soluble glue when you place the finished piece, you simply water sponge the paper, then peel off the paper.If the thinset is set, it won't pull the tiles. |
| I've only tried the indiredt method with a small project and I used contact paper. I was too impatient and peeled it off too quick and ended up with crooked tile! I think you've gotten some good advice about kraft paper and water soluble glue....you can learn a lot here... like, the god of wind's name is Astrias. :) It's a beautiful mosaic, btw. |
| Welcome to the group... .I have to agree with all about the brown craft paper and weldbond glue...Only I would not do it that way, I would be different and do the whole thing on the fiberglass mesh and then set it into thinset. I really like picking up the whole thing or pieces and setting it down, done...quick is for me. I have yet to do an indirect where you lay your tiles upside down, but I doubt if I could do it as I don't follow a pattern and my design changes as I go. I never know what I will do next..lol I love your design and think it is beautiful, if what you do next is half as nice it will be a knockout. |
| Hey Flag that is usually what I do, just start and let it happen. I get all flusterd when I try to design a pattern then mosaic it. I'm not sure I would use Weldbond tho, expensive, elmers will work if you are going to sponge it off. |
| Thanks for all your advice. I'm more of a planner than a design-by-the-seat-of-my-pants kinda gal. I need to have a pattern to work from before starting a project. I've been reading all the posts and enjoying the pictures of your projects. Wow, lots of talent here. Dianne |
