- Posted by ladyronnie (My Page) on Wed, Jun 27, 07 at 21:41
- Posted by ladyronnie (My Page) on Wed, Jun 27, 07 at 21:53
- Posted by shellybelly26 (My Page) on Wed, Jun 27, 07 at 22:04
| where are you getting the epoxy youre using |
- Posted by mosaicwench1 (My Page) on Wed, Jun 27, 07 at 22:05
| What a great tutorial - thanks for the info! |
- Posted by brendak_59 (My Page) on Wed, Jun 27, 07 at 22:18
| I think I will try this. I also want to know where you get your epoxy? |
- Posted by bamasusanna (My Page) on Wed, Jun 27, 07 at 22:33
| Wow! You really put a lot of work in this presentation. Thank you so much for taking the time to do it. I'm going to save it to my file!! |
- Posted by chickeemama (My Page) on Wed, Jun 27, 07 at 23:20
| lady- thank you thank you!!! I have done this before but did NOT know about the alcohol...boy that would have saved us some frustration had we known that!!! I've not done anything big before. Did you mix the epoxy all once when you did the counter top or did you do it in batches?? You might have said but I sure don't remember if ya did.. |
- Posted by ladyronnie (My Page) on Wed, Jun 27, 07 at 23:54
| Thanks everyone. I got the epoxy at a local True Value hardware store. We don't have a Lowe's, and Home Depot didn't have it. It cost $21.19 +tax for the quart size (two pint bottles, a pint each of resin and hardener). CHICKEE: When I did the vanity, I did each side, the front, and the top separately. (That's why I had to do the tape "form" when I put it all together, to do another layer on the countertop to cover the seam between the top and the sides/front, if that makes sense.) So I did it in five batches total, if I remember right. |
| Hey, that's right spiffy-- good job on the tutorial. Nancy |
- Posted by ladyronnie (My Page) on Thu, Jun 28, 07 at 11:29
| This morning I peeled the paper from the edge and back of the tile, and I learned something. Epoxy does not stick well directly to porous tile. This was actually a good thing. This was a little tile sample, with the grid relief on the back, so the epoxy ran under it as well. The paper was stuck to the entire back of the tile, soaked through 3-4 layers of paper. It peeled off hard, but it did peel off cleanly, with no sanding needed. Looks like where I painted the sides with epoxy it would peel off if I tried very hard, but I won't unless it really starts to come off on its own. It DOES stick permanently to the glass/grout. (It does NOT stick to silicone though, I learned on the back edge of my vanity where I had run a bead against the wall. So be sure the silicone is all covered with grout well if it comes up between your tessarae.) Veronica |
| Wow thanks. Great job explaining!! Maria |
| I know you probably already covered this in some earlier post, but I'm coming late to the game. I really like the way the epoxy looks...is it for interior & exterior projects? And you said you used it on your sink, was it to keep the moisture out or for the smooth feel? Linlee |
| Ronnie, thank you for such a detailed tutorial. Very informative. |
- Posted by ladyronnie (My Page) on Thu, Jun 28, 07 at 13:49
| AAAAAND you got to see my Alien Ears and Grandma Chin! ;D) |
- Posted by bamasusanna (My Page) on Thu, Jun 28, 07 at 14:17
| What? Where????? |
- Posted by curbdiver1954 (My Page) on Thu, Jun 28, 07 at 21:16
| Really GREAT tute!! Thanks for sharing your knowledge and experience in oics.....much easier for some of us to grasp! Pat |
| Thank you so much for taking the time to create this wonderful tutorial for us. Great job. Very sweet of you. I'm sure I'll want to do this at some point - so I'm definitely saving this! Thank you so much! |
| Was I asking a stupid question.....again? Linlee |
- Posted by crackpotannie (My Page) on Fri, Jun 29, 07 at 10:56
| Thanks so much Ronnie you saved us all a lot of mistakes! |
| I don't think so linlee. I'd like to know too. Can you use it on exterior projects?? Maria |
| Great tut! Thanks for sharing the tips on the bubbles! On my watering can I actually used resin on that swap project. |
- Posted by ladyronnie (My Page) on Fri, Jun 29, 07 at 16:05
| LINLEE: Sorry I missed answering your questions. No, it is not recommended for exterior applications. And on your other question, yes and yes :) It works beautifully to keep moisture out, but my main reason was to make a perfectly smooth surface. I didn't tumble the glass (this was only my second or third project, didn't know about tumbling glass!) and there were some edges that could have been a problem. The epoxy solved that, and it looks great, it actually enhanced the color. Veronica |
- Posted by brendak_59 (My Page) on Fri, Jun 29, 07 at 19:38
| Does anyone know what you should put in your tumbler for glass? I picked up a tumbler at a flea market with no directions or owners manual. |
| brendak- I just put the glass and water ( about 1/2 full). I tumble it four about a half hour Maria |
- Posted by ladyronnie (My Page) on Tue, May 27, 08 at 19:54
| bump Just checked out page 67 to see what might be falling off, and this was the last thread on that last page. Might still be useful to someone someday... Roni |
| I'm glad you saved this. It helped me a lot when I used it ! Thanks !! |
- Posted by mermaid4life (My Page) on Tue, May 27, 08 at 21:19
| Thanks for bumping this up, I'm going to save it. Thanks so much |
| Good save Ronnie! |
| THANKS! Wish I would have had the brains to look this up before I did the wine lady tray! She turned out OK, but reading your tut I can see where I could have made it easier! |
| Hi, have a question for you--I want to do this on some coasters I made a while back. However, the coasters were made in a mold using concrete. The tiles are glass. Is concrete considered a porous surface? You mentioned that the resin won't stick to a porous surface, so I thought I'd ask before I go out and buy it. Thanks |
| What a beautifully done tutorial! (I love the piece too!) Thank you so much! Now if I want to keep a copy of this, how would I do that? |
- Posted by ladyronnie (My Page) on Tue, Jul 15, 08 at 19:47
| It's always flattering to see one of my old threads pop up. Thanks :) POMMOM: It was just a happy accident to discover that the epoxy didn't stick to the back of my tile in this tute. I truly don't know if it would stick to concrete without testing it. I am assuming you DON'T want it to stick, like to the backs of your coasters? If so, the best thing to do is elevate your coasters off the surface (which is well protected with something as the epoxy WILL run off the sides). I didn't elevate the tile because I knew I could sand off the edges, just was happy to discover it wasn't necessary. You could use something like pieces of popsicle sticks, or foil balls, or even pebbles, just MAKE SURE they are well inside of where the epoxy will drip off, so they don't become adhered to your coaster! Does that make sense? You will have hardened epoxy drips on the edges, but they sand off very easily, especially if you have a belt sander. DAISY: You can save the text in Word or something similar, but how to make the pics go with it I don't know, as they are in my photobucket account. |
| Oh this is great timing. A friend of mine has talked me into returning to a craft show.(I gave them up 4 years ago)I wanted to do some small things and coasters came to mind. I have tons of tiles leftover from the ceramic days. Thanks so much Ronnie. Daisy, I just save them in the clippings up in the top right corner of the posts. |
- Posted by mermaid4life (My Page) on Tue, Jul 29, 08 at 13:29
| Ronnie, Question on your wonderful tutorial. I did my first epoxy test on my door hanger. So what have you done if you used grout sealer, or even decided later you wanted to use the epoxy and forgot if you sealed it?? I am so glad I didn't try this first on my sea turtle!! LOL. It was kinda fun actually, like the chemistry set I wanted when I was a kid that my parents never bought me!! Thanks |
- Posted by ladyronnie (My Page) on Tue, Jul 29, 08 at 17:34
| Hi MERMAID. I'm glad the tutorial was helpful for you. To be honest, I have used epoxy on 1)my bathroom vanity...1st experience with it, thankfully a positive one! 2)a gourd vase and 3)that little tile in the tutorial. I have never tried anything that was sealed first. If it hasn't hardened in 24 hours, it's probably not going to, though someone with more experience might tell you to give it more time? Maybe you could call or email the manufacturer? Sorry I can't be more helpful this time! |
- Posted by mermaid4life (My Page) on Tue, Jul 29, 08 at 20:54
| Ronnie, Good news on mine. The epoxy did harden and I really LOVE the gloss. I'll take a pix tomorrow and show you all. Because I have a different sign on each side, the epoxy did run onto the back side and make a bit of a mess. I used old tile to sit the sign on, upside down, with a ton of paper under that.I know I mixed up too much epoxy and lots of it ran over the edge and when it hardened it stuck the tile and newspaper to the sign. I think, after rereading your tut, i should have put the tile facing down with good side next to the sign. As it was, the old tile had a lot of drywall stuck to it and that got stuck to the epoxy and to one side of the sign. I did get it all peeled off and plan to do one more light coating on that side of the sign. Thinking I'll be brave and do Ms. Loggerhead tomorrow, though hopefully someone migh ttell me what I should do since I already used sealer on her. I also used sealer on this sign, and it did work. |
- Posted by mermaid4life (My Page) on Wed, Aug 6, 08 at 17:55
| Lady Ronnie, Could you tell me how your bathroom counter is doing with the epoxy/resin now?? I am thinking of using resin on my small glow in the dark backsplash. I am debating whether it would be easier to keep clean and get less water spots with the resin than without. I know you did one awhile back so just checking. Thanks. By the way, I will post but DH is rearranging his office and I can't get hooked up to the digital camera, but I did use resin on Madam Loggy and I love the look. Also did my door knob signs. so shiny and glossy.. Reminds me of those beautiful coffee tables back in the 70's made from real logs and resin coating.... i'm bablling. sorry |
- Posted by ladyronnie (My Page) on Thu, Aug 7, 08 at 19:42
| Well, I have tried and tried to get a good current picture of my bathroom vanity, and I think all I have accomplished is to realize that my new camera simply doesn't take as good a photo as my old camera! I THINK the vanity has yellowed SLIGHTLY in the past year and a half, but the second photo makes it looks like it has REALLY yellowed. But if you notice, EVERYTHING in the second photo looks yellowed! (And we don't smoke, so it's not that!) Bottom line is, I am still quite pleased with how it turned out, and how impervious to water it really is. |
- Posted by mermaid4life (My Page) on Thu, Aug 7, 08 at 20:37
| Thank You so much for taking an updated pix. You are so sweet. I still haven't made up my mind. Really love the resin look and your bathroom sink looks so fantastic/ Hopefully I can post pix soon of Madam Loggy and my door signs. How do you get your spirals so perfect?? Do you draw them ahead of time?? I can't seem to get mine to look right, specially on my yellow brick road pot, it is just all wrong.. thinking of tearing it apart and starting over |
- Posted by ladyronnie (My Page) on Sat, Aug 9, 08 at 16:26
| MERMAID: I drew the original swirl, the one I cut out, then flipped it over and traced it for the red swirl, which I did in red glass. There is a mirror placed behind the cut-out swirl in the finished piece. Here's a WiP pic: As each row of glass was added around the outside, it kept the same curve going. HTH! |
- Posted by mermaid4life (My Page) on Sat, Aug 9, 08 at 20:32
| Ah ha!!! Thank you so much. Those are perfect curls.. Still haven't made up my mind on my backsplash, |
| Your tutorial was very helpful and was exactly the information I was searching for. I noticed this epoxy was interior. Is there is an exterior epoxy? I made a two sided house number sign and would really love to keep it outside all winter (In Maine!) Has anyone ever left a mosaic out all winter in freeze/thaw temperatures and if so, what did you do to prepare your mosaic piece? Any information would be great. |
- Posted by mermaid4life (My Page) on Sat, Aug 30, 08 at 13:06
| Brenda, I would LOVE to know the answer to that too!! I would so love to find something like this for outside, but I haven't seen anything like that yet!! Maybe someone else knows. ?? |
