Tile Murals
Posted by darrah (My Page) on
Tue, Jun 1, 10 at 17:03
Someone from the "Kitchens" forum suggested I might have luck posting my question on this site, so here goes:
I would like a tile mural over my kitchen sink as there is no window. I know I will tire of looking at the same mural every day for the life of the kitchen. I got the idea that as money allows I'd like to be able to change out one mural for another. That means the mural cannot be permanent - it would be attached to a board framed with a braided tile trim. Now I know I could just hang a mural over the sink but my fear is because it isn't permanent it would look odd, cheap or both. I thought if I created a nitch in the wall that the mural would recess into, it would allow the mural to come out even with the surrounding tile so that it looks like it is there permanently. (There is no tile on the wall yet - just a plain wall.)
Anyone have any suggestions how I could approach such a project and make it look cohesive?
RE: Tile Murals
I like your idea of a nitche in the wall, DARRAH. Hope you'll post pictures of your work in progress. For many years, I've wanted the nerve to cut out a niche in one of my walls in order to either put something into or to make a mosaic. You seem to have figured out the answer to your question. As for myself, I never get tired of looking at my mosaics I've made permanent on my walls or in the garden. They give me pleasure every day. Go for it, and follow your art.
RE: Tile Murals
I wonder if you could use Velcro. I saw on the internet where someone used industrial strength Velcro glued to the back of a piece with E-6800 silicone adhesive(also known as 'ShooGoo'), and the mating surface of Velcro was glued to the wall.
So if you created a niche, and then all your mosaic murals were exactly the right size to fit into the niche, then you could change them out. How cool would that be?
RE: Tile Murals
Thanks so much for the responses. We are planning a kitchen makeover hopefully in the near future and at the time stuff is tore out would be the time to do this nitch if it is possible.
I use to do porcelain painting and have thought of getting back into it and creating something unique for that spot over the sink.
Haven't been creative in so long and realize how much it was a part of my being, like breathing. Unfortunately life got in the way and had to put hobbies on the back burner. Looking at all the lovely pictures on this forum has definitely inspired me to get back to what I loved doing.
RE: Tile Murals
Welcome to the forum Darrah! This project sounds delightful!! Hope you get time to start a mural...AND keep us posted...with pics...we are like sharks with a feeding frenzy, when it comes to pics!ha!
RE: Tile Murals
If the mural is not permanent, you can use plywood as a backer. Better yet, use wallboard. Cement board will work, too.
I like the idea of the recess, and the velcro idea is smart.
Use regular tile mastic to stick the tiles, and sanded grout. I am assuming you have experience with tile murals, so won't bore you with details on how-to.
You will still have to consider how to finish the edges between the mural and the recessed tiles - I would recommend tubabd tile grout in a color that closely matches the grout color. It can be easily scraped off when the time comes to replace, and it will prevent moisture from getting behind the works and mucking things up in the future.
Good luck, and would love to see pics of the progress as well as the finished product.
RE: Tile Murals
I don't know how extensive your wall re-do is going to be. But another idea instead of cutting a nitch into the wall is to built an extention onto the wall. Attach a 'permanent frame'to the wall, making it part of the wall, using stucco or however your wall is finished. Either finish it different or match the wall, so your work will pop. You could even do several of them. I think it might be easier and you could still 'set' you work into it. I hope this made sence!
