Tue, May 10, 11 at 13:26
| Last year I made my very first mosaic. I did a large clay pot. After I finished it, I found out I was supposed to have "sealed" it first. Now I'm afraid to use it outside and plant anything in it. I used clear outdoor caulk to attached the tile and then I used sanded grout. Is there anything I can do to make it usable? It looks kind of silly sitting on the garage bench.....lol |
| What I would do: Seal the grout (if you haven't already) with a sealer that says it's for outdoor use. Seal the inside of the clay pot. Then find a plastic pot that fits inside your mosaic pot and place your plant inside that liner pot. Then leave outside and see what happens! What has happened to my mosaic pots is that over time, the plant water leaches out through the grout and discolors it. |
- Posted by concretenprimroses (My Page) on Tue, May 17, 11 at 7:41
| Someone on garden junk (Jan in Ca I think) seals her pots with spray car undercoating. Maybe if you let the pot dry out really well you could try that on the inside. Has to be very dry or the moisture could be trapped inside espceilally if you have already sealed the outside. Good luck. Kathy |
