Sharp edges on table top -Advice needed
Posted by ch_glass (My Page) on Mon, Feb 1, 10 at 19:17
| I have a friend that just finished mosaicing a table top with broken porcelain tile. It will be used outside. He was not real careful in making sure the tile pieces were level, has some very wide grout lines, used unsanded grout, and wiped too much out of the grout lines. Now...he wants to know what to do about the sharp edges that are exposed - there are plenty.
I had the following ideas: Pour some of that epoxy resin over the top. Regrout over existing grout with thinset (hoping that the adhesive properties of the thinset would adhere to the grout). Cover the top with plexiglass or plastic sheeting. He thinks putting a thick coat of polyurathane would work -- I think it would chip right off.
Feedback, anybody? |
RE: Sharp edges on table top -Advice needed
| Resin may be his best bet. He could try going over it with sanded grout |
| I don't think there are any resins rated for outdoors. He could go over all the offending ahards with a dremel and smooth them off a bit but I agree with Shrty, he should go over it with sanded grout |
| In my beginning days mosaicing I used polyurethane, and it clouded. Don't recommend it, but NT is right, dremel or carborundum stone and/or re-grout. |
