fabric or paper under glass
ernie85017 (
Tue, Feb 14, 12 at 13:50
I have seen mosaics with pictures, letters, and even fabric adhered to clear glass, then used as a custom mosaic tile.
Does anyone have a link on how this is done? |
RE: fabric or paper under glass
| this real issue is to use a glue that doesn't soak into the paper or to seal the paper before hand. I have had success with silicone with this, Some ppl swear by doing modge podge 1st,, and I have even closed clear tape over something 1st. wwhat ever you do, never use the original photos because it is a risk. |
| I have had great success with fabric under clear glass. I lay down a sheet of plastic, then the fabric, right side up, then coat the piece of clear glass with Mod Podge. Then I press the glass down onto the fabric. I hold it down firmly, then release. Then I go back several times and press down firmly to make sure that the glass is completely adhered to the fabric with no gaps. After it is thoroughly dry, I lift it up and with sharp scissors I cut the fabric close around the edges of the glass. |
| Same here - I use Mod Podge on paper or cloth. I give it several coats of MP to make sure it's completely sealed b/f putting the tile down. |
Oh --- no .....another idea to use !!! LOL Thanks for the post and replies - I was always wondering about that. |
Would weldbond brushed on work the same as modpodge? The package says it makes a good sealer when diluted. nana: I am not sure what you did. Is that crash glass over it? It's so sparkly! |
| Yes crash glass and I do use a lot of glitter some times. |
| You could try Mac glue, it is also supposed to be good for glass on glass. I think it is available from Maryland mosaics or one of those mosaic online shops,in the US, might be expensive, but a little goes a long way, use sparingly. |
How does Mac differ from E 2000 (I probably have that number wrong, but you know what I mean), weldbond and silicone. How many different glues can there be? Weldbond seems to be a glorified Elmer's. |
