Fri, Aug 12, 11 at 14:33
| How did you make the frames? Specifically, how did you put the frame pieces together? Mortise & tenon, biscuits, or something else? And did you dado a groove in the inside center of the frame pieces, or on an outer edge, or how did you set the beadboard into the door frame?
I hope you see this today as dh & I are going to work on the doors tomorrow. Thanks! |
- Posted by flgargoyle (My Page) on Mon, Aug 15, 11 at 11:55
| Sorry I just got your message- Internet access is very limited here in SC! I made the frames out of poplar 1X3. I cut a groove with a dado head to fit the paneling, then cut a matching tenon on the cross pieces. I assembled it with glue, but no glue on the infill, which you want to leave a little room for movement. |
| That sounds like the best way to do it. We ended up using biscuits to join them together though. We didn't glue the panels either. Today is joint sanding. Ugh. |
- Posted by moccasinlanding (My Page) on Tue, Aug 16, 11 at 11:04
| Way to go, Marti! It sounds like progress to me. And having a really real beadboard construction is something to be proud of. Awesome. Oh yeah. I hope you remember to take pictures for your own benefit, presanding, and as you begin the finish, and then after you finish, and then as you hang them. It is a long process, and you don't need to forget how much went into creating them. |
| Thank you ML. It's not real beadboard though, it's beadboard paneling. We've got all the doors built. I need to go clean up the sawdust and then start painting. But I'll take a pre-photo so you can see where we're at. |
