| We recently bought a mobile home last fall as a second home and there is a really bad smell to it. We ripped up the old carpets already, painted all of the walls, used glade plug ins, bleached/cleaned all cabinets and surfaces but the smell is not going away. We are going to the house tomorrow morning and need some good ideas to try to get the house smelling better for when we re-open it in April.
I am planning on setting up a dehumidifier in the crawl space basement, plugging in some air freshners, and putting white vinegar in bowls in each room. Does anybody have any other ideas that might help get rid of the stink?
- Posted by writersblock (My Page) on Fri, Feb 25, 11 at 13:49
| What kind of smell? Mold, dead animal, old smoking, what? |
| not really sure what it is. Might be a combination of all of the above. There was definitely signs of rodent droppings in the house. |
- Posted by moccasinlanding (My Page) on Fri, Feb 25, 11 at 19:32
| Oh boy. If someone left out poison for rats, and it was not the kind that dries them up into mummies which do not stink, then you may have a dead animal smell. I'd also recommend that you check out any sewage connection which may be beneath the mobile home. They might have had a crack in the plumbing and some seepage dried in the insulation. Then again, do you know what a skunk smells like? That odor lingers a long time if it sprayed on the premises. I'm just going down the list of things that I know can smell pretty bad. Include mold on that list too. |
- Posted by moccasinlanding (My Page) on Fri, Feb 25, 11 at 19:39
| You mentioned using vinegar before, but you can get better results with the vinegar if you do this: Put it in a pan diluted by half with water. Add some cinnamon and some cloves. Then let it simmer and simmer for a long time inside your mobile home. I've used this as an odor eliminator for years, having used it to remove the smell of diesel fuel from commercial boats, to remove fish cooking smell in any place, to get out the smell of smoking from a house, and I recommend it as a way to get RELIEF until you find the cause of your problem It smells like apple pie. It won't remove the mold and mildew itself, just the smell. If you wash the walls and the a/c ductwork with it, that might help. Be sure to change out all your a/c filters and your range hood filter. |
- Posted by writersblock (My Page) on Fri, Feb 25, 11 at 21:07
| >If someone left out poison for rats, and it was not the kind that dries them up into mummies which do not stink, then you may have a dead animal smell. Yes, but at least it will go away eventually, if that is what it is. |
- Posted by moccasinlanding (My Page) on Sat, Feb 26, 11 at 18:42
| BambRose, if it is flooded under your house in the crawl space, it very well could be mold. You asked if the dehumidifier would take away the one inch of water in the basement, and I don't think it will, but then I'm not a person who ever lived with a problem basement. There is a Basement Forum where some of the folks might be knowledgeable on this. Do you have a mobile home, or a manufactured home? Can you also turn on a couple of box fans to move air through the space? Ventilation can help dry it out, but if it is a paved crawl space you are dealing with, it won't be draining into the soil. Good luck. |
