Singer 6268 HELP!
Posted by iowafarmersdaughter (My Page) on
Thu, Aug 14, 08 at 17:30
I hope that I am using this forum correctly; if not could someone direct me elsewhere?
I was given a Singer 6268 computerized sewing machine with a lot of fancy stitches on it. The machine turns on and all the buttons seem to work, but the motor won't respond to the foot switch. There is air going through the hose on the foot switch(the foot switch seems primitively built for a computerized machine). Is there anybody out there that has one of these machines that can give me a clue of what might be wrong with it? It has worked some in the past, but this time it won't respond at all. I have heard that you can bypass the computer board attached to the foot switch(if that is what is wrong. . .), and hook the motor up to an electric foot switch. Any thoughts? Thanks!
RE: Singer 6268 HELP!
Know the foot pedal can be replaced. Saw a site when I googled your machine.
Not familiar with your machine, have singers.
Does it have a button that you can use it without the foot pedal? Thought it would be a way of testing.
Do you have any friends with singers where you can try their foot pedal?
Just check the type of plug yours uses.
Some have the small 2 holes and some have larger plug.
