| Hi....I think this elastic is called Soft Stretch elastic. It's been so long since I've bought any, but had some left over from another project.
I am putting this elastic in a pair of shorts for myself. I'm going to run it through the casing and then stitch the opening closed. On the outside, I want to do about 3 or 4 rows of topstitching. 1)Do I stretch the elastic as I'm top-stitching? If so, how much? 2)Should I cut the elastic my waist size (plus 1" for stitching ends together), or should I cut it smaller? I have alot of experience in sewing, but not when it comes to topstitching over elastic. Thank you. |
- Posted by oilpainter (My Page) on Thu, Jul 8, 10 at 16:54
| First-- I don't understand, I thought soft stretch only came in narrow widths, but then I'm from Canada and ours may be different than yours. In any case it is not good for waistbands. Use a good waistband elastic. Waistband elastic has up and down ridges that keep it from curling over like regular elastic will. You cut the elastic comfortably stretched to fit your waist. You want the elastic to fit like you would want it on your garment, plus the extra for overlapping. At least that's how you do it for an elastic waistband. The topstitching may stretch out the elastic more. Now topstitching elastic is hard to do if you've never done it before. You have to stretch the elastic as much as you can while sewing a straight line. Personally I never top stitch. I make my casing just a touch over the width of the elastic and then thread my elastic through. Then I stitch straight up following the line of the front and back seams |
- Posted by kathi_mdgd (My Page) on Sat, Jul 10, 10 at 21:03
| Also if you top stitch elastic and you need to remove it someday,that's a lot of work ripping out all that stitching.I do the same as oilpainter,and then i sew an X in the center back,so i know back from front,especially when sewing for kids who don't need pockets . kathi |
Return to the Sewing Forum
