patch removal
Posted by not_the_man (My Page) on
Mon, Jun 30, 08 at 19:16
I have a garment that has a patch sewed on at the factory and I wanted to remove it. Will removing the stitching affect the strength of the backing fabric at all? It's critical that the strength is not compromised. Thanks
RE: patch removal
Be careful trying to remove factory applied patches. It may be heat bonded to the backing fabric which will make it impossible to remove without distorting, possibly tearing the fabric.
Check the edge of the patch with the tip of a seam ripper. Is the patch held on by thread or does it appear glued down?
If you can remove the patch easily it shouldn't affect the fabric beneath. Unless the patch was applied to cover a defect. Did you check the reverse side of the patch area?
Good luck.
