molly bolts in drywall
Posted by homebound (My Page) on
Sat, Dec 8, 12 at 20:32
I needed to hang a 30 lb wood-framed mirror on drywall with those dang keyhole hanging slots. No room for error. No studs in the location where the hangers needed to be. So I ended up using molly bolts. I had not realized until today that there's a little flat "wrench" to hold the molly head (when using it in drywall) while you tighten it. Cost me 24 cents at my trusty old-school hardware store.
Did any of you guys also know about this little "wrench" gizmo? Seems to be a very well-kept secret.
This post was edited by homebound on Sat, Dec 8, 12 at 20:59
RE: molly bolts in drywall
I know there is a "setting tool" that works like a pop-rivet gun to expand the molly without rotational force. I've never heard of a special "wrench".
Can you post a picture of your wrench?
Sure, I'll post it later. I probably should call it a tool instead. It basically holds against the flange teeth while you first tighten it so the whole thing doesn't spin.
The wrench used to (ad sometimes still does) come if you purchase boxes of 100 bolts at a time.
The setting tool is far better and usually under $15.
One pull of the lever and the bolt is expanded in place.
Probably too late, but you don't have to use the keyhole hanging slots. You could use a French cleat.
Here is a link that might be useful: Hangman french cleat
I considered a french cleat, but it wouldn't work in this case. The mirror frame was concave due to leaning on the wall over a mantel for years (and I didn't really want to drill into the old wood).
Basically I extended the molly screws out about 3/8" inch to reach the keyholes to make it appear to hang plumb overall. This was tricky also because I had an interior designer of 35 yrs experience in the room at the time.
