Cracked Grout in Kitchen Backsplash
Posted by pjray55 (My Page) on
Thu, Dec 17, 09 at 20:07
Hi All,
I am hoping someone may offer some advice.
We renovated a 1938 Cape and gutted the kitchen this past May. We had noticed slivers of grout coming out where the granite meets the backsplash and notified the GC. I came home tonight to find his solution was to use a clear caulk in that area as a repair. I wanted to see if this is acceptable or a poor attempt at a band-aid?
Any help or advice would be greatly appreciated.
Patrick
RE: Cracked Grout in Kitchen Backsplash
Caulk, colored to match the rest of the grout, allows the countertop to move without cracking the grout. Which cracked because cabinets/countertops will move independent of the wall.
The caulk should have been used instead of the grout in the first place.
Using clear is a bandade---to negate having to remove the old cracked grout and do it right.
They grouted a joint that should have been caulked in the first place.
thank you both for the input and advice; much appreciated
